  #11
Old 07-Aug-2005, 00:14
Mood: Avatar what Avatar
Me too everton and NBs996 said (don't forget to lube your ring)
  #12
Old 07-Aug-2005, 00:28
748IOM 748IOM is offline
Mood: Yellow!!
Probably best I don't know about this.
  #13
Old 07-Aug-2005, 17:50
aka.eric aka.eric is offline
Just at thought,sure its the oil filter,leaks from the slave cylinder,clutch pushrod,engine cover,can end up with a drip around the filter.
  #14
Old 08-Aug-2005, 01:14
The filters leak if they are put on dry. You need to smear the seal with engine oil before fitting it.
Chances are, the seal will stay stuck to the cases when you remove the filter.
They don't need doing any tighter than hand tight when replacing them.
  #15
Old 08-Aug-2005, 02:01
Carbon749's Avatar
Mood: I own a flame thrower
Originally posted by 748IOM
Is there a bit of "run it gently period" after changing the oil?
No not at all, I work in the oil industry and can assure you that the important thing is to get a good quality oil and then check the level after your first blat to check that all is ok.
  #16
Old 08-Aug-2005, 15:11
RickyX's Avatar
RickyX RickyX is offline
I have an "oil" leak that I thought was the oil cooler joint. It manifests itself as a drip on the engine case centreline and then onto the exhaust.
I have installed a new oil cooler after cracking my one (doh!) but have found the drip is still there.
NOW...I have noticed that the fluid level in the clutch m/cyl has reduced noticeably since I topped it up approx 2 weeks ago!
I rekon you are right as I know my old 748 used to leak from there.
R X
  #17
Old 08-Aug-2005, 15:23
For a moment I thought this thread was about a short-a**ed cockney doughnut eating geezer...
  #18
Old 08-Aug-2005, 19:26
Crunchy's Avatar
Crunchy Crunchy is offline
Oil filters for Ducati or should I say Twins are know to shake loose. My mechanic tightens them so tight, you need to stick a screw driver in there to get it out and some times that does'nt work. He does this because he has had atl east 9 drop oil on the track.
I change my oil every time I go on the track and fit a Jubilee Clip to the filter and then wire it to the frame. It saves having to over tighten it and the hassel of removing it later.
If you do change the filter/oil make sure you clean the pick-up filter as well
  #19
Old 13-Aug-2005, 02:59
DEMON's Avatar
DEMON DEMON is offline
Mood: on the back wheel !!
""they come off easy enough with out a tool. and yep the O ring comes with the new filter""
its not an O ring, its a square section rubber joint !!
  #20
Old 13-Aug-2005, 03:00
DEMON's Avatar
Oh nad oil filters have a torque setting which you are supposed to use to tighten them to your engine too..read your haynes manuals you naughty boys !!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:10.
