  #41
Old 27-Oct-2005, 16:07
guest1 guest1 is offline
Originally posted by Rally
Hey, I'm just trying to help out here!
Yes, the rear nut requires a 36mm socket. I think we've established that.
But there seems to be some doubt over the torque setting so I put up the pdf so people can look it up for themselves. It says 180 Nm (+-10%) (or 132 lbft if you're Rockhopper )
(scouse accent) Calm down, calm down.
I only know the socket size for sure cos I adjusted the chain last night.
As for the 180Nm, I personally employ a midget to come and hold the socket whilst I turn the bike.
Always been 180Nm from 03 to 06.
It also says in the manual that chain adjustment should be done by dealer.....OMG, Is my warranty void now?
  #42
Old 27-Oct-2005, 16:50
Rally's Avatar
Rally Rally is offline
Is that a 1/2in midget or 3/8th?
  #43
Old 27-Oct-2005, 17:28
Yep,you can lead a horse to water............!
  #44
Old 27-Oct-2005, 21:21
duc daz's Avatar
duc daz duc daz is offline
its a 36mm socket for sure
  #45
Old 27-Oct-2005, 21:26
chris999 chris999 is offline
Mood: red and proud !!!!
jesus -- this has turned into some thread..
not being funny but if you think M30 nut is the socket size (30mm) maybe someone more knowledgeable should be adjusting such a critical part of the bike ...
+ this has been covered before in this section (correctly the first time) - search !!!??
just a thought ??!!!!
  #46
Old 27-Oct-2005, 21:28
mark749s's Avatar
mark749s mark749s is offline
if you measure a nut or bolt across flats this is the corresponding socket/spanner size. if you measure your back wheel nut you will find it is 36mm across flats
another piece of useless info
mark
  #47
Old 27-Oct-2005, 21:37
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
Can I just add that the tolerance on the given setting is +/- 5%, not 10.%....
Ducks, grabs coat & heads for cover
  #48
Old 27-Oct-2005, 22:06
logyk's Avatar
logyk logyk is offline
Mood: Relaxed - don't worry about things you can't change
'Kin 'ell....trying to get you lot to agree anything is like getting unanimity in the HoC !
So its 180nm is it ?
  #49
Old 27-Oct-2005, 22:16
Davieravie's Avatar
Davieravie Davieravie is offline
Mood: Warmed up and ready to go
Use the old method we used on aircraft....180 Nm is roughly three and a half white fingers or 4 if you are a girl....SIMPLE!!! :P
  #50
Old 28-Oct-2005, 09:52
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:52.
