  #11
Old 03-Dec-2005, 23:36
keefer's Avatar
keefer keefer is offline
Originally posted by m1keyp
Discaciatti
www.redracingparts.com
Awesome mod
for the recommended billet brembo ducati clutch M/C they want
£237.98 inc all the trimmings
thats naff
[Edited on 3-12-2005 by keefer]
  #12
Old 03-Dec-2005, 23:45
Nah...youll get a billet brembo cheaper than that!
  #13
Old 03-Dec-2005, 23:53
Only paid £100 for a new Cluch Radial master cylinder today, well chuffed.
As for the Reservoirs I get mine from Denise Trollope Racing or Harris Performance, usually only around £6 for the small pot.
For the brake lines I come off the Mastercylinder with a single banjo and use a banjo bolt with the built in pressure switch, then I put a T piece in just above the bottom yoke so the brake line running to the left caliper takes a route across the bottom yoke before dropping down.
As I only have them on my 998 and 996 sorting the brackets was easy as you can use one of the bolts that holds the clip-on bar in, obviously noy a option on the 999s.
  #14
Old 04-Dec-2005, 00:15
.......option, unless you have harris clip ons!
  #15
Old 04-Dec-2005, 00:25
If they are like my Harris clip-ons with the single 6mm pinch bolt clamping the bar from the front then a bracket should be fairly simple and like the ducati bars will probably require a small spacer just to sit in to the recess meant for the bolt head.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:00.
