  #21
Old 02-Sep-2003, 11:38
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
Thanks for the thought but the OE air filters are still in the intake tubes, they should hopefully stop any rubbish getting in. I dont have any other filters installed.
I'll have a look though and speak to the dealers when I get the bike back - see next post!
  #22
Old 02-Sep-2003, 12:40
swiss 998s swiss 998s is offline
I guess that removing them also "frees up" volume in the airbox which should have a similar effect to increasing the size of the box by 1l or so. The effects as I understand of a bigger box is to lower the helmholtz resonance and hence boost mid range.
I have heard the counter argument that installing an in tank filter takes up volume, increasing the frequency of resonance, so the opposite should apply when removing the blocks
  #23
Old 02-Sep-2003, 21:56
psychlist's Avatar
Mood: Lucky? For some, maybe!
Not got my 998 yet but......
how do you remove the restrictors?
  #24
Old 02-Sep-2003, 23:02
Do a search on the old boards.Loads of threads on the subject.
  #25
Old 03-Sep-2003, 10:12
pguenet pguenet is offline
Dead simple although quite a pain ... You undo all the little screws holding the air tubes and plit them in 2. Then you can remove the filters.
One thing though, be patient and use a good screw driver, those screws are a pain to remove and if you start rounding one up you are buggered!
  #26
Old 04-Sep-2003, 23:37
Monty's Avatar
"if you start rounding one up you are buggered!" technical term that Phillipe??
John
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:06.
