  #21
Old 26-May-2006, 09:25
iang's Avatar
iang iang is offline
I have just fitted an underslung rear caliper bracket on my 749R and I cannot bleed it so it looks like I will have to lift the caliper as suggested to bleed it.
Cannot be as bad as the 2 days I tried to bleed the brakes and clutch after I fitted the cycle cat riser kit. I could not get any fluid to come through even using a hydraulic bleed kit from a local dealer, after taking the system completely to bits, guess what it was !!!!!!!
Yes, the plastic reservoirs had plastic bungs in them that I had failed to spot when fitting them, 15 minutes later the job was finished !!!
[Edited on 26-5-2006 by iang]
  #22
Old 26-May-2006, 09:37
khushy's Avatar
khushy khushy is offline
you mean you fitted the reservoir hose on top of the plastic bungs???
maybe you should NOT be pi*sing around with your brakes - ever thought of that??
[Edited on 26-5-2006 by khushy]
  #23
Old 26-May-2006, 09:48
Murray Mint's Avatar
Oh I very nearly did the same thing once, thought the hose felt a bit tight.
  #24
Old 26-May-2006, 09:52
khushy's Avatar
scary!!!!
  #25
Old 26-May-2006, 09:55
khushy, I keep looking at your avatar and wondering what it's all about.
  #26
Old 26-May-2006, 09:57
khushy's Avatar
have guess - what do they look like?
  #27
Old 26-May-2006, 10:02
khushy's Avatar
is that better?
  #28
Old 26-May-2006, 10:07
Antthing to do with Rossie?
  #29
Old 26-May-2006, 10:09
khushy's Avatar
good job you can spell!!!
who is Rosie??
  #30
Old 26-May-2006, 10:16
OK if you want to be cryptic then so be it, if you want to tell me what its all about then do so or don’t……
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:17.
