  #11
Old 22-May-2006, 18:59
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
The use of warmers on race days can be disputed due to the delays in holding areas. Often the delays on trackdays are less because you can ride out onto the circuit at any time in the session.
Warmers help preserve tyre life due to reduced heat-cooling cycles but, with non-race tyres this is not so important.
Tyre warmers do help you with confidence and by ensuring your tyres have heat in them but, I really don't think it's a big deal with trackdays as you also have to warm more than just tyres anyway. It's not a race so there is no need to go balls out to start with. A few moderately gentle laps sighting should be enough to start getting heat into the tyres before picking up pace.
I raced used Diamond warmers for two years - they are great vfm. Not the most robust or hottest but, then you should look after kit anyway - mine are still like new. On cold days the use of skins is required to help them retain heat.
  #12
Old 22-May-2006, 21:22
deej's Avatar
deej deej is offline
tyre warmers are ace, onyl used mine the once but made a hell of a difference. tyres are only designed to have a few heat cycles so get them up to temperature and keep them there, in from the session warmers on, warmers off at the last minute :ie as their opening up pit lane then you not sat in the lane waiting letting your tyres go cold
buy a set you wont regret it
  #13
Old 25-May-2006, 15:51
Nattyboy's Avatar
Nattyboy Nattyboy is offline
Mood: Back down to 3 :>(
Some good advice here lads - what do people think about the motogp ones as a budget item - ive heard there actually not too bad at all for the money ??
Nat
  #14
Old 25-May-2006, 15:52
Nattyboy's Avatar
Originally posted by weeksy2
pretty much everything he said.
only downsides are not being able to use them at Mallory/Cadwell/Anglesea
Sorry for being thick steve - but do you mean because of the lack of leccy points...?
  #15
Old 25-May-2006, 16:33
Felix Felix is offline
MotoGP ones are certainly cheap but not heard much good. They may be ok for very occasional use but don't expect to last too long. Diasec are probably the best vfm. And, yes, it's the lack of leccy points, genny required (more than those small 800 W jobbies).
  #16
Old 05-Feb-2007, 16:12
Nattyboy's Avatar
Any feedback on these ? Notice they are half the wattage of the diaomond ones though.
http://cgi.ebay.co.uk/Superbike-tyre...QQcmdZViewItem
Curiously, both Diamomd and euroquip boast petronas as users ??!! Someones fibbing...!!
Nat
  #17
Old 05-Feb-2007, 20:29
Bungi Bungi is offline
I Went For Diamond And They Work Just Fine
  #18
Old 08-Feb-2007, 19:08
injected's Avatar
injected injected is offline
Mood: Blown away!
Nat
Maybe one on the front and the other on the back??
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:37.
