  #11
Old 02-Oct-2003, 11:20
John W's Avatar
John W John W is offline
My 996 has a DP rear hugger, fitted using just the two bolts as I didn't want to drill the extra hole in the swinging arm.
While in France last weekend it lost the rear bolt and ended up being pretty much only held on by the rear brake hose as the front bolt was also nearly out !!
Guess who's going to be drilling the third (bolt) hole now...
Cheers,
John.
p.s. yes I do maintain my bike, and do check it at the end of every ride. This was after 1200 miles over 3 days of serious riding.
  #12
Old 02-Oct-2003, 12:40
rcgbob44's Avatar
rcgbob44 rcgbob44 is offline
Bikes: 998s, Jota, KTM 690 Duke
Mood: My Jota goes rumpety rump! & I have my wife exactly where she wants me!
John
Its an easy job, the swing arm is thick and can be drilled and tapped without any problems, mine is 5mm and all is well, never flaps or comes lose.
Regards
  #13
Old 02-Oct-2003, 13:30
Lee1980's Avatar
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Mood: Xdiavel..awesome!!
Mine was drilled and now seems fine. I like the shape as well with the little lip bent up on the end.
Lee1980
  #14
Old 02-Oct-2003, 14:16
John W's Avatar
Lee1980
Yeah, that little lip stops it from digging into the tyre when all the bolts fall out !!
  #15
Old 03-Oct-2003, 06:00
Nigel Booker's Avatar
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
I had only the two bolts holding a dp hugger on my 748. When the top bolt came out it moved so much that it ended up touching the underside of the exhaust and burnt an 1" x 2" hole in the hugger.
  #16
Old 10-Oct-2003, 22:24
the phantom pieman's Avatar
the phantom pieman the phantom pieman is offline
Mood: Sort of shuffling along .....
Use Velcro, works a treat
  #17
Old 10-Oct-2003, 23:02
rcgbob44's Avatar
only on bra`s.....................doh!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:54.
