  #21
Old 02-Aug-2006, 12:16
Sharpy G's Avatar
Sharpy G Sharpy G is offline
Bikes: 749R 2004
Wink SBK
Originally Posted by doogalman
Bit of a misrepresentation with the number plate . Should be fitted to a 999 not a 749. WSS would have been the one!!!!!
erm....it does say SBK on the tank
and its in Ducatis SBK section aint it ?!
toys out of pram .!....................it is a Superbike ! yes it is !!
  #22
Sharpy G's Avatar
Bikes: 749R 2004
BY THE WAY.......for anyone reading this, I do still need the measurement at the beginning of this rambling post
LOL
  #23
Old 02-Aug-2006, 13:12
doogalman's Avatar
Steady tiger!!!
  #24
Old 02-Aug-2006, 13:33
Sharpy G's Avatar
Bikes: 749R 2004
Talking
Steady tiger!!!
Only kidding mate, just made me laugh that I got all these relpies but no dimension
G
  #25
Old 02-Aug-2006, 13:52
Gizmo Gizmo is offline
Mood: is it the weekend yet??
G
DPP slipper plate is 115mm internal diameter i'd think the 749R would need to be the same as the basket will be same tooth outside diameter.
  #26
Old 02-Aug-2006, 14:02
Sharpy G's Avatar
Bikes: 749R 2004
Gizmo
thanks, it is 115mm dia inside of teeth, but I need to know what the diam is on the 749R one without the teeth so I can machine them off
cheers
  #27
Old 02-Aug-2006, 14:05
Buy a proper bloody cover.....or better still a proper clutch!!!!
oh yeah were back to that again.
  #28
Old 02-Aug-2006, 14:16
Sharpy G's Avatar
Bikes: 749R 2004
DP don't do a pressure plate for the 749R
so this is the only option
"AndyB - you n your 'proper clutches' LOL
like my modded one at the mo
seems to work well with my new Corsa IIIs"
what was it you were saying about roundabouts ?
  #29
Old 02-Aug-2006, 14:29
Gizmo
cheers
the 749R should be the same, the teeth are on the basket and the basket is the same between bikes cos the clutch plates fit between bikes. So, if the DPP slipper has clearance from the basket teeth the same machined out diameter will work on any slipper pressure plate as it has to clear the same teeth, if you get my drift....
if that ain't enough try measuring across the teeth on your final steel plate, and leave a little clearance, if its close to 115 I'd probably go with that
  #30
Old 02-Aug-2006, 14:33
If you bought a proper clutch........you could measure that...........
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:40.
