  #11
Old 15-Sep-2006, 20:48
marko's Avatar
marko marko is offline
Mood: happy
if I was you Jools I would give nelly a ring, I'm sure he wuoldn't mind.
  #12
Old 15-Sep-2006, 21:19
Thanks for all the replies guys...I still think that the oil was overfilled from when I bought it, cos although it's on a paddock stand, the path the bike stands on is on a slope...so when it's on the stand the bike is actually on the level. I'll start it up tomorrow and see if the overflow happens again now that the tiny bit of overfilling the header tank caused it to spit coolant out. I will try whipping the spark plugs out as well to see if there is water getting into the bores.
One thing i do know is that if it is a head gasket the oilway bit of it hasn't blown because there was no water in the oil and there is no oil in the water.
Plenty of time to sort it...the 888 goes on SORN for the winter next week and the ST comes out to play
___________^
  #13
Old 15-Sep-2006, 21:26
marko's Avatar
Mood: happy
Jools it could just be condensation,
  #14
Old 15-Sep-2006, 22:41
Aah,its fooked mate.
Tell ya wot,..bring it 'round here,....I'll take off yer hands.
  #15
Old 01-Apr-2007, 17:16
851neil 851neil is offline
Mood: need a bike...
Jools, did you get this problem bottomed out ?? if so would you enlighten the masses ?
cheers
Neil
  #16
Old 01-Apr-2007, 23:11
Hi Jools
Had the similar problem not long ago and it was a case of over filling the coolant it was spraying all over the rear.
Have you tried bleeding air out of all the bleed points?
Get a compression tester and plug in to each cylinder and compare with the manual a big difference between cylinders will show up allow for some reduction due to wear but they should be close, but be carefull as it could have poor readings due to worn rings but this normally causes crankcase over pressure and oil blowing out the breather.
ian
just looked through my Ducati Workshop manual and cant find the psi settings for each cylinder as someone's already said Nelly's your best bet.
  #17
Old 02-Apr-2007, 13:50
Well, I did suss out what was wrong and it's quite alarming....but not in an expensive way.
Since it's been laid up for winter, I've been turning it over every couple of weeks to make sure the belts don't get set in one position. Since the fairings are off and in bubble wrap up my loft it's been easy to use Nelly's trick of disconnecting the crank sensor and turning it over until the oil light goes out.
One day, the lure of hearing it start got too much, so I plugged the sensor in again and tried firing it up....turned over a bit sluggish, but....nothing. Gave the battery another charge and it turned over faster but...nothing.
OK, try the age old checks for fuel, sparks etc...but I didn't need to look far, I popped the fuel cap and found the tank was bone dry. I had put it to bed with about a litre in the tank so I was suprised to find it had all gone in a month or so. Evaporation? wouldn't think so....
Anyhow, I sploshed a little fuel in, the pump primed and the old girl started at the first prod of the starter. I warmed it up...no smoke...no drama...nothing. Kept it running until it was good and warm and the fan cut in. No problems at all. Then I got to wondering why the fuel had run dry and started checking for leaks. Sure enough, one of the hoses is weeping....ever so slowly (even with the pump going it's about one drip every 10 minutes). That would explain why the bike always smells as if it's just come back from a run...funnily enough it's not a raw petrol smell but more like the mix of hot oil and hot brakes. Anyway, I reckon what was happening was that there was a very slow drip of petrol when the bike was standing that splashed off the rear of the crankcase onto the surrounding bits, a real slow seep so that there really wasn't any petrol pouring out and not so much as to soak the area or make it wet...just enough so that all the volatile stuff evaporated leaving a bit of residue to burn off.
Fixed now....
___________^
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:57.
