  #21
Old 25-Oct-2006, 10:13
Derek's Avatar
Derek Derek is offline
Bikes: ST4s ABS
Rushjobs write up had encouraged me to get round to doing mine this winter but alas Desmotimes have discontinued the ST stainless strips. Looks I'll have to make my own (it doesn't look difficult) or do the job without them.
  #22
Old 25-Oct-2006, 13:12
moto748 moto748 is offline
Originally Posted by Jools
One question...I always found Dzus fasteners a little bit temperemental on rally cars, do you have any problems with the ones under the engine? Considering all the salt and grime gets thrown up there, will they be OK for the job in the longrun ???
Works OK on a 748/99*, Jools.
Occasionally in winter I've known them get a bit gummed up, so you needed a pair of pliers to twist them rather than your fingers, but it's no big deal.
  #23
Old 25-Oct-2006, 13:50
He only makes them in batches, you have to order and then wait till he's got enough. Took about six months to get the ones i ordered.
  #24
Old 26-Oct-2006, 13:22
How much are they?
  #25
Derek's Avatar
Bikes: ST4s ABS
Not much chance of getting them for this winter then?
  #26
Old 26-Oct-2006, 13:31
$35 ish for the pair from memory.
http://www.desmotimes.com/
Note the producation discontinued adition since i ordered them!
Perhaps if lots of you get together then he might make another run.
  #27
Old 12-Jan-2007, 11:44
Derek's Avatar
Bikes: ST4s ABS
Rushjob, What length are the Dzus fastners you used?
Tasty nuts do them in stainless steel at half the price of their anodised alloy ones and I rather fancy stainless than alloy or zinc plate but they only come in 17mm length. Will these be OK or will I need 19mm?
I'm about to do this conversion in the next week or two.
  #28
Old 12-Jan-2007, 13:34
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
I used standard Ducati ones which, when I've just measured them, from the underside of the flat on the head to the end of the fastener are 15.97mm!
I'd say use the 17mm. (this is the one they recommend for Ducatis on the website anyway.)
You will need to tweak the back of the receptacles to get the correct fit as I mentioned, or at least I did!
  #29
Old 12-Jan-2007, 14:19
Derek's Avatar
Bikes: ST4s ABS
Great. Thanks for your prompt reply. I'll order them today.
  #30
Old 12-Jan-2007, 20:11
Chief R.B. Chief R.B. is offline
Mood: looking to move in a new direction...
Evening
This is a great thread, I've been thinking about converting my ss and this has given me a lot to go on. Well done and thanks for taking the time to post everything up Rushjob.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:13.
