General Motorcycles only
  #11
Old 20-Nov-2006, 22:11
keefer's Avatar
keefer keefer is offline
on my second set
they are both dry as a bone
and if they were wet I would return them
but that's just me
oil is supposed to be on the inside not out
  #12
Old 20-Nov-2006, 22:24
Wylie1's Avatar
Wylie1 Wylie1 is offline
I may be well wide of the mark here, but my WP forks on my offroad bike have an outer dust seal. It's good practice to remove this seal, clean underneath & pack with grease, then refit the seal. After doing that, there is a smear left on the slider from the grease, but it soon stops doing it. Could it be grease on your Ohlins or is it definitely fork oil?
PS. PM me what you've been up to Sean.
  #13
Monty's Avatar
Ohlins forks are generally noted to be less well sealed than most others-however, I don't think you should have any noticable film on forks juts serviced.
I would call Mark at K-Tech and ask advice-they are the boys for Ohlins and run the service truck for a lot of BSB guys.
John
Growing old-disgracefully!
  #14
Old 20-Nov-2006, 22:34
keefer's Avatar
Originally Posted by everton
Fraid they're fooked the seals that is!
I had residue on my fork legs - Andy from Ducati UK took one look and arranged for them to be replaced (both legs) under warranty.
you had more than residue
it was like a dog had cocked its leg on them
  #15
Old 20-Nov-2006, 22:44
Wylie1's Avatar
Bungi.....you could try http://www.hmracing.co.uk/default.asp
My mate swears by them for everything suspension related. They're based near Orpington, so just up the M20 for you. They should be able to have a look & give you an independent opinion. Might be better than trying to describe your problem over the phone.
  #16
Old 20-Nov-2006, 22:47
khu996's Avatar
khu996 khu996 is offline
Originally Posted by Bungi
so have you a set of ohlins on your bike? have they been serviced / how old are they, and if you pump them up and down and run your finger over the leg?
are they dry as a bone?
I'll check again tomorrow, but when I refitted the forks, and just pumped them to settle the axle, I remember seeing a tiny film of oil.
I'll clean the stanchions and try taking another look...
  #17
Old 20-Nov-2006, 22:49
jj250's Avatar
jj250 jj250 is offline
Try calling mark hammond at mh racing, always been really helpful in the past
http://www.mhracing.com/
  #18
weeveetwin's Avatar
My own 888SP's (FG9050 Ohlins) are away at Maxton being rebuilt at the moment. During a telephone conversation with the boss (Richard Adams), he told me that these forks were designed to leak a little oil past the seals in order to reduce the effects of 'stiction', and thus give them a more supple/responsive feel.
Whether this is true of all Ohlins forks I don't know.
  #19
Old 20-Nov-2006, 22:51
jj250's Avatar
Ive read exactly the same thing in the past
  #20
Old 20-Nov-2006, 23:08
Bungi Bungi is offline
interesting ! do you have any referance to this reading
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:48.
