  #11
Old 26-Jun-2006, 13:09
Scooter916's Avatar
Mood: Hmmm Conference season
Fil we bung rear tyres everyday and have never had an issue with them, I would do it on my racebike thats how confident i am in the repair.
glyn
  #12
Old 26-Jun-2006, 22:17
ath748's Avatar
ath748 ath748 is offline
Mood: Missing my Flash...
Repair. Did it on a Bridgestone BT010 on my R6, rode it for another 1000 miles or so, regularly topping a ton etc. No probs, especially as it's in the middle.
  #13
Old 26-Jun-2006, 22:44
Keep in mind that a tire manufacturer is in the business to sell tires so there's really no reason for them to suggest patching a puncture. However, Dunlop (to their credit) offers this advice:
"Dunlop recommends only permanent repairs performed from the inside of the tire, using a combination patch/plug method. Never attempt a repair from the outside, or inject a sealant, or simply use an inner tube, a patch or a plug as a substitute for a proper repair. Only a qualified tire repair shop or motorcycle tire dealer should perform repairs. Inspection of the tire and adequacy of repair becomes the responsibility of the person actually performing the repair and Dunlop does not warrant the results of a repair in any way."
That just about covers their butt, but there IS a point to be made here ...
You need to use a proper repair kit and materials, and only on tires suitable for repair. If you're going to do the repair, then YOU have to remove the tire from the wheel and do the inspection yourself. Here's some guidelines for either you or the tire repair shop:
The tire should NOT be repaired if:
• The puncture is larger than 1/4-inch in diameter
• The puncture is not perpendicular to the carcass
• The puncture is in the tire sidewall.
• There are any cut or separated plies
• There is any bead or carcass damage from running the tire flat
• The tire has been previously injected with a sealant/balancer
• There is more than one repair in any quadrant of the tire or there were two prior repairs to the tire.
  #14
Old 26-Jun-2006, 22:54
glyn
Blimey - would you ?
  #15
Old 26-Jun-2006, 22:59
Scooter916's Avatar
Yea no worries, I have done them on Mucho more powerfull bikes with no issues, so long as the repairs are done correctly, and obviously the damage fits into the repairable catagory then there is no reason why not, And its a lot cheaper than a new tyre.
Glyn
  #16
Old 26-Jun-2006, 23:01
Ok Glynn - I defer to your greater knowledge on this subject. To date it wouldn't have been an option for me at all. In fact had a puncture on Dessie 3 days before Assen, replaced the tyre without a second thought.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:06.
