  #11
Old 29-May-2009, 19:54
Originally Posted by 007
Thanks indeed guys, should be fine as I am then.
Regards
Certainly should be, my 998 was OK last year on 50mm Termis and the 748 was OK on 45mm Sil-Motos
I wonder if my 998R will be OK on 54mm Termis
  #12
Old 29-May-2009, 20:19
Flash git !!!
  #13
Old 29-May-2009, 20:56
Ray's Avatar
Ray Ray is offline
Originally Posted by Paul996
Had my S4R checked today with a full Sparks system and came out at 105.6db know wonder my neibours were not to happy with me
Looks like I may need some db killers, company said they wold supply and fit for £50, would take 3db of level.
What RPM did you have it checked at?
If the db killers are easy enough to fit/refit I'd just bring them as "insurance" no point bunging yer drainpipes up unless you really have to
Ray.
  #14
Old 30-May-2009, 00:29
Paul996's Avatar
Paul996 Paul996 is offline
Bikes: S4R
Mood: Ready for Summer
They checked it at 5000rpm.
Still trying to workout whether to take/fit the db killers or fit the standard system back on need to get it mot'd in a couple of weeks anyway.
Confused
  #15
Old 30-May-2009, 10:25
Confused
it should be fine with db killers.... then all you have to do is find a friendly MOT station
  #16
Old 30-May-2009, 18:59
MSV noise test is listed as
The noise limit for bikes is 105dB(A), measured statically at 0.5 metres and 45deg angle, at ¾ maximum rpm.
So a bit more revs than they rev'd the DD bikes to at Snetterton last weekend
  #17
Old 31-May-2009, 21:05
Paul996's Avatar
Bikes: S4R
It was tested as stated. Decided to put the standard pipes back on. It had bought a cat removal pipe, and when i went to do an oil change today, the full race system blocked removal of the oil filter. So thought if I had to take it off for oil change i might as well change the whole thing over
Sounds so quiet now.
Might see if i can get the race end cans altered so they will fit on the standard link pipe?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:45.
