  #11
Old 12-Jun-2011, 21:57
Hit it with the big hammer Craig
  #12
Old 12-Jun-2011, 22:39
Thanks again Phil, Yea I did try the misting in that I was spraying fuel into the top of the carb, and yea I had it slip a tooth at Mallory.
Ok its now at a point where its beyond me to continue as I dont have a compression gauge or how to use one.
I'll have to call my mechanic( Skids ) after Snett.
Thanks for your help Phil.
See you at Pembry hopefully
  #13
Old 12-Jun-2011, 22:57
Craig we also disturbed the inlet manifold at Mallory when getting ready to take the cylinder head off, before I noticed the timing was a tooth out, so it could have an air leak, if so it would effect the fueling.
In the mean time I had better did out my compression checker (normally use a leak down check these days) I could pop over late tomorrow afternoon / early tomorrow evening with it if thats any help
  #14
Old 12-Jun-2011, 23:42
If you have time Kev that would be most appreciated. Just give me a call and bollox to work I'll leave early
  #15
Old 14-Jun-2011, 20:56
brummydave's Avatar
DSC Member brummydave brummydave is offline
just a simple one that happened to me craig,check that all the blanking screws are still in the inlet manifold,i must have lost one at mallory and it would only run on 1 untill you revved it or applied choke,fitted new screw all good
all the best brummy dave 96
  #16
Old 14-Jun-2011, 23:09
Hmmm Thx Dave.. I'm pretty sure I remember seeing one as we took it out to reseal it with liquid gaskit. But I'll sure go check that.
  #17
Old 14-Jun-2011, 23:13
There is one each side of each manifold I think Craig.
  #18
Old 14-Jun-2011, 23:14
Ghosty---- you still hovering in here.
Kev did a compression test tonight and there is nothing wrong with that, if anything the fron pot is better.
Kev had the carb in a thousand peices and that all looks ok.
You can see the front pot spark plug is a little wet so fuel getting in, not igniting right ? As said before it will run on this one pot if you give it some revs but not smooth but no poping or anything.
What would you ( anyone )check next
thx
  #19
Old 14-Jun-2011, 23:35
John W's Avatar
John W John W is offline
when you swapped the coils, did you try swapping the plug leads too ? (that assumes the will fit)
I had the same symptoms on my 998 when the front plug lead went bad.
  #20
Old 14-Jun-2011, 23:50
Yup just ran out to the shed and there is just one in each & they are both there.
Thanks though Dave
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:14.
