  #11
Old 17-Jul-2004, 13:39
ss29 ss29 is offline
also when it bogs down its quite like a miss fire or off a cylinder ??????????? help still needed.
  #12
Old 18-Jul-2004, 02:17
Karl's Avatar
DSC Member Karl Karl is offline
Just a thought..but you could try checking the throttle body are tight against the intake manifold and the jubilee clips are secure.
  #13
Old 18-Jul-2004, 11:08
Does sound like a faulty TPS.
  #14
Old 18-Jul-2004, 20:11
I'll check them, its at its worst when im in 6th and just cruising along about 4000rpm and when i accellerate may it be hard or gentle at 4500rpm it just starts to bog down and vibrate like its of a cylinder and it doesnt want to rev and its very slow to pull out of it until about 5500rpm and then its fine again
  #15
Old 18-Jul-2004, 20:25
den den is offline
Had same on my 996bp turned out to be a faulty TPS as rockhopper sugested
  #16
Old 18-Jul-2004, 20:45
den, was it expensive, easy to fit yourself ? cheers
  #17
Old 18-Jul-2004, 21:50
den den is offline
Dont know how much it was as the dealer had replaced the fuel pump first saying that was the problem so I never got charged for it the pump was around £90 so I would imagine the pot was a lot less!! the dealer set everything up for me
  #18
Old 18-Jul-2004, 22:02
I think a TPS is about £120 ish. Sorry.....
  #19
Old 18-Jul-2004, 23:12
rockhopper, do you know is this a direct replacement part that i can fit myself or does it need to be a dealer job, £120 ouch but if it cures it, its well worth it, cheers
  #20
Old 18-Jul-2004, 23:59
Robbie Robbie is offline
Mood: Variable
Fitting/adjusting a TPS is not "hard" per se. But it is an almighty fiddle. I've done it on a 2 valver & it does improve running markedly.
Check out the FIM website for instructions.
Robbie
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:14.
