Old 19-Jan-2005, 11:44
03-04 Monster Gearing
Heres the thing......
I've been looking into gearing this week and found that Renthal don't make a rear sprocket over 46 teeth for this model, which to me means that anyone running a 03-04 620ie is going to have very limited gearing options if they want to sacrifice top end for acceleration.
Standard
15/48 - 3.20
Options
14/45 - 3.21 (almost same as stock)
14/46 - 3.29 (slight improvement)
14/48 - 3.43 (best your gonna get using the stock rear and a new 14t front)
Dropping below 14 on the front isn't really an option (?)
I would expect everyone to drop the gearing at our first outing (Cadwell Woodland) so are the new Monster boys already at a disadvantage??
Unless any other manufacturer are making bigger than 48 tooth rears for the newer bikes.
Old 19-Jan-2005, 11:51
or........
is it going to get even more complicated and gearing be assesed using only the first 4 or 5 gears in the box, which means lots of practice time with a lap timer and spannering.
I suppose by the end of the first weekend we will all know how to change the rear wheel blindfolded in the dark
dickieducati's Avatar
i wont be chuffing around with gearing too much else to worry about.
i would have thought you would gear for top speed anyway everywhere apart from on the woodland and maybe the extra little bit of power a stock 620 has over a 600 will make up for it?
shouldnt having 6 gears as oppsed to 5 on some of the older bikes help too?
Old 19-Jan-2005, 12:13
I think the 6spd box will be an advantage because it gives more flexibility when selecting gearing - but only if the parts exist (sprockets) to expoilt that advantage to the max.
Old 19-Jan-2005, 14:59
following on from Weeksy's point
I see the 2 important areas at Cadwell (woodland) as the exit from Barn and the loop back from the end of the start finish straight onto the Mountain. Two conflicting parameters !!
I can't see the little bikes pulling 6th on the straight coz you can't gear them down enough so pulling max revs in 4th or 5th 3/4 (or so) of the way along the straight has to be a goal subject to the correct gearing for the drive out of Barn.
Theres no precedent so that means....
Fit a 14t front before race day and then experiment with up to 4 different rear sprockets and possibly 2 chains on the day......
I'm reasonably handy with a spanner, but thats still seems like some work to fit into what I assume will be quite a limited practice/qualifying session
Old 19-Jan-2005, 15:11
sometimes i feel out of my depth with this desmodue lark................this is one of them!
with regard to gearing i was just going to check i had 6 of them and then get on with it
not that it really mattars but standard gearing on a 2005 is 15/46
Old 19-Jan-2005, 15:18
weeksy,
assuming i'm an average rider (at best) will i really notice a difference between different gearing or should i just concentrate on getting round the track ??
Old 19-Jan-2005, 15:30
ali's Avatar
ali ali is offline
Mood: Damp
Originally posted by dickieducati
weeksy,
You'll definitely notice it.
I only did a few track days last year, buton my first one I was bitching about been completely mis-geared for the Russell Chicane at Snet. Everytime I came out I'd get wasted by people who were already in the power in second while I was bimbling around at 1500rpm or screaming in first...
Also had the same (as did a few others) with Club corner on silverstone GP. Should be a fast double-apex right which opens out, but on an SS/SL the standard gearing sees you shifting up mid-corner. This led to the single biggest 'moment' I've ever had on a bike
I'm sure Weeksy is bang on the money, get it right for one corner and another's buggered. Just depends on where the best over-taking opportunities are and how your bike makes its power.
ali
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:35.
