Old 20-Nov-2005, 17:59
Harv748's Avatar
Harv748 Harv748 is offline
Originally posted by Nattyboy
Did the 9 mile round trip to halfrauds for my new tool..first turn..un******believeable
Im going down the pub !
Nat
I'm not laughing Nat...thats not funny
Old 20-Nov-2005, 18:08
dave996's Avatar
dave996 dave996 is offline
Mood: Fed up...
Nat I have a blow torch (the one for welding copper pipes) and some OK allen keys (they got my tight nuts off, ohh err).
I'm just up the road and could possible get down tomorrow lunch time, I need to see duke2bsteve anyhow.
Steve glad to see you got rid of that mythical horse
Old 20-Nov-2005, 19:00
Halfords.....Professional..........
Old 20-Nov-2005, 21:00
I have a few Allen keys around where I have chopped off the shorter bit to just leave the longer bit, The 8mm and 10mm ones go straight into the appropriate sockets and then fit onto the airgun. Originally made them up for removing the damper rod bolts when taking forks apart. But work well on stuborn chassis bolts.
Old 20-Nov-2005, 21:30
888heaven 888heaven is offline
Mood: UKGS'ers Non PC and Vibrant
Natty
is it the same configuration as the T8 if it is you will need to lock off the nut on the other side with a socket and T-bar wedged against the swinging arm then get a air/hammer gun and industrial quality sockets I think machine mart do a quality set.
when you replace the bolt I can send you a S/S one if you give me the dim.
ian
Old 21-Nov-2005, 11:31
Nattyboy's Avatar
Nattyboy Nattyboy is offline
Mood: Back down to 3 :>(
Thanks guys...b***y halford havent got any more sockets in stock..
D2BS..If you can U2U me your number, any help would be great ! I promise not to be one of those blokes who nips round all the time pinching yer tools....
Nat
[Edited on 21-11-2005 by Nattyboy]
Old 21-Nov-2005, 13:38
RickyX's Avatar
RickyX RickyX is offline
I had trouble getting the bottom bolt out on my 748 a couple of years ago.
The problem is that the bolt head on LHS corrodes into swinging arm bore.
I had to carefully drill the head off (without damaging s/arm) and also the flat edged bush on RHS.
Once both ends of bolt were drilled off I then had to drift the remains of the bolt out.
If you have snapped an 8mm socket drive allen key then I rekon your bolt is corroded into the bore.
It's that dissimilar metal situation again - it's a b*gger!
R X
[Edited on 21-11-2005 by RickyX]
  #18
Old 21-Nov-2005, 19:19
Duke2BSteve's Avatar
Duke2BSteve Duke2BSteve is offline
Natty,
Sorry mate was actually at work for once!!!!
Give us a ring on 07811280214 anytime mate, got a couple of bits from Dave996 as well which might help..
Steve
  #19
Old 22-Nov-2005, 22:03
dave996's Avatar
Mood: Fed up...
Nat is it off yet?
  #20
Old 22-Nov-2005, 22:22
Dave, not heard from Nat yet?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:40.
