Old 28-Nov-2005, 21:20
andya's Avatar
andya andya is offline
Disc Thickness
Hi
Been trying to order some disc bobbins from Nelly and he needs the disc thickness. He says normally 4.5 or 5mm.
So I measured mine and they seem to be 4mm. There is very little disc wear and they seem to be 4mm on the braking surface and near the carrier where there is no wear at all.
Can anyone confirm what the discs thickness is normally on a '93 strada?
Andy
Old 28-Nov-2005, 21:43
Andy, check the carrier itself for the wear limit.
5mm discs usually have 4.5mm limit and the 4.5mm usually have a 4mm limit.
It's the original disc thickness that makes the difference when supplying new bobbins.
Double check first, but 4mm may be down to the limit
Old 28-Nov-2005, 22:05
andya's Avatar
Hi mate
Just looked at the discs again, there is no wear limit stamped that I can see and the measurement is 4 mm even on the part of the disc next to the carrier which gets no wear.
I have looked at the workshop manual for the 888 and the disc thickness seems to be listed at 4mm also, so I'm puzzled......
Old 28-Nov-2005, 22:47
I'm guessing these are fixed discs then? The bobbin is riveted, not secured with an E-clip?
I'll need to check my info at work tomorrow to make sure the replacement bobbins are a viable fix for you.
Old 28-Nov-2005, 22:48
OOOOPPPs............................. siad it all twice just to be sure
Old 28-Nov-2005, 23:09
phil911's Avatar
phil911 phil911 is offline
Mood: Privileged ...
Sometimes, the informations regarding the MIN thickness are written on the circumference of the disk ...
You have to clean and brush if rusty ...
Phil911
Old 29-Nov-2005, 17:18
keith888's Avatar
keith888 keith888 is offline
Mood: On the up
Mine is also a '93 and definately has 4mm thick disks as I've just checked (there is almost no wear on mine). They look rivetted so they are 'fixed' or possibly might just classify as 'semi-floating'.
Keith
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:14.
