Old 30-Jan-2006, 17:57
Ducnow Ducnow is offline
Originally posted by JPM
Originally posted by Ducnow
Strange..... my 04 R has the switch.
Does your's have it to JPM?
Now you're asking a question I just can't answer, mine never ran on the road with lights on, first thing I did was whip the headlight assembly off and fit a trackday kit
Really?
So, how many miles do you have on her? :P
And did you took off the switch also?
Old 30-Jan-2006, 18:00
WAIT!!!!!!!!!!!!!!!!!!!!
Forget all i've said.
Mine doesn't have the switch
Old 30-Jan-2006, 18:07
All Dukes from '04 onwards have the light switch blanked off.Drain on the battery is not a problem as the lights go out as soon as the starter button is pressed.The lights and ignition also shut down after a while (15secs?) to save power if the ignition is left on.
MY '02/03 bikes had the light switch fitted,I'm guessing the switch should fit straight on to a later bike.
For track days its a fairly simple job to remove the lighting fuse.(I think its the first one nearest the h/light.)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:11.
