Old 27-Jun-2006, 16:37
CipiVTS's Avatar
CipiVTS CipiVTS is offline
Track preparations
Hi all,
I have a few probs with my 916 at the last race.
1. After a few laps the brakes lost their efficiency. I'm running DOT 5.1 fluid, standard discs / pads. What do you suggest i should get in order to improve the braking? I also noticed that my right hand gets tired a lot by pulling the brake lever... i rode a Honda CBR 600 RR and the brakes needed just a light touch for the same efficiency of my Ducati...
I have 748 2000 forks/calipers/brake pump
2. Throttle: I have the standard handle bars and the standard throttle and my hand gets very tired to twist the throttle at max all the time.
Are there any options like adjustable handlebars needed?
Thanks
Old 27-Jun-2006, 16:43
khushy's Avatar
khushy khushy is offline
sarchastically speaking . . . .
lay off the 5.1
apply some brembo pads and DOT 4
dont go so fast
do a bit of DIY!!! (with both hands)
get yourself down the gym
loose some unsprung weight
or failing that - get a CBR!
Khushy
Old 27-Jun-2006, 16:45
khushy's Avatar
Seriously Speaking . . .
you have probably shagged your caliper seals with the 5.1
get them done and change to dot 4
experiment with your riding position and RELAX - you are holding on too tight - be careful with the DIY!!!!!
Khushy
Old 27-Jun-2006, 17:05
CipiVTS's Avatar
from what i know DOT 5.1 is perfectly compatible with DOT4. I think you're talking about DOT 5...
I have to hold tight cause we're racing on old airports with bad quality pavement and if you're not holding it you can really bounce off the bike... but that's it... every body is having the same conditions so that's not an excuse.
as for height/weight i'm 1.82 m and 75 kg so i think i'm ok for the moment
you;re right about the gym part... i'll go starting this week at least 3 times a week.
I'll DO MYSELF as you suggested every day... no... twice a day to get fit
Old 27-Jun-2006, 17:08
CipiVTS's Avatar
Here's a picture of the "track"
Old 27-Jun-2006, 17:50
I would stay with the Dot 5.1 as you say it is the dot 5 that is the problem one, change your pads to Bendix or an equivilent race pad, better still get some P4 calipers & a Brembo radial master cylinder, thet set up will not fade.
Chris.
Old 27-Jun-2006, 18:57
khushy's Avatar
"I'll DO MYSELF as you suggested every day... no... twice a day to get fit "
watch the arm pump - I am sure there are a few here who can give you some advice about that!!!!!
8-)
Khushy
Old 27-Jun-2006, 19:56
CipiVTS's Avatar
Talking
8-)
Khushy
Sure they do mate
thanks chris for the advice...i'll go for some race pads asap
Old 27-Jun-2006, 20:25
Felix Felix is offline
The biggest, i.e. most effective, change you can make to your brake system is to fit 18x20 radial master cylinder and some good pads. Bendix, the new Brembo RS, Performance Friction, are all good choices.
Old 27-Jun-2006, 21:18
PDL's Avatar
PDL PDL is offline
Bikes: 803 rs race bike
I use EBC HH rated pads with stock Brembos and they alway do the job for me.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:35.
