Old 02-Feb-2009, 11:31
superfly superfly is offline
Bikes: ducati 888, kawasaki zxr 750 h2, vellocette mac!!
Mood: anger managment failure
Single seat info please
Does the single seat that ricambi weisse fit straight on to my strada,or does it need modding,or do i need to change the rear subframe.I also see qb carbon do a gel coated one would i have the same issues.
Old 02-Feb-2009, 15:00
ace ace is offline
Talking
is it a mono strada ? if so i would say yes if its the same shape 851/888 if its a bip strada get the hacksaw and welder out !!!
spike
Old 02-Feb-2009, 15:20
ace ace is offline
right these are the subframes . the alloy ones are left sp3 right sp4 and i,m asuming youve got one , if its a bip like the one on the bike ( black) it wouldnt take much to make it fit looking at em side by side
spike
Old 02-Feb-2009, 20:22
paynep's Avatar
Mood: Wet wet wet
You can make the Ricambi or QB units fit a 888 strada subframe - I did it in my racebike!
I ditched the grabhandles and cut off the sticky-up posts that locate the strada rear seat panels.
I also had to make up small brackets to allow me to mount onto the oe wellnuts on the bottom rail near the exhaust hangers.
I also used a couple of bits of pipe lagging in strategic locations to keep everything in place.
I was going to do the same thing on my '92 851 strada but find the underseat storage area more useful than looking like an SP.....
Old 05-Feb-2009, 18:03
I have fitted a QB seat to my 888 Strada. All it needed was a bit filed off the front bracket supporting the locating pegs, to allow the seat unit to sit lower. A bit of black paint and you could not tell it had been modified.
More difficult was cutting the seat unit so I could keep the original frame mounted seat pad.
Old 09-Feb-2009, 13:53
Nattyboy's Avatar
Nattyboy Nattyboy is offline
Mood: Back down to 3 :>(
QB one here too. I took a few pics while I was modding it if you want them as a reference
Old 10-Feb-2009, 09:19
That would be great if you could nattyboy,did you use the carbon one or the colour impregnated grp one?If it is a grp one is the colour a good match for the rest of the bodywork?Qb are only a couple of miles from me so i will be getting one from them.
Old 10-Feb-2009, 09:52
Nattyboy's Avatar
Colour GRP - avoid white in case of chips etc.
Have a word with Ian the owner and ask for a cash deal ;>)
PM your e-mail and i'll send over the pics I have. I may also have some pics from another owner that were sent to me before I started.
There is quite a buit of prep work, smoothing seams, cutting out for the light recess, sanding out runs etc, but with a little time and care the result is worth it. I have a supply of the proper ducati number 1's too if you need them (satin finish) which go on unlaquered after the seat is finsihed...Heres a pic of mine done..(best I could find showing the seat!)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:52.
