Old 21-Jul-2009, 17:40
Paul James's Avatar
Founder Member
Trackday Tyre Pressures
Just had a pair of Supercorsa 3's fitted to the 996R and wondered if anybody has advice regarding tyre pressures for trackdays? I guess the pressure goes up quite a bit once the tyre is warm so if normal pressures at cold are used do the pressures get too high when warmed well up?
Even a starting point to try would be handy.
http://www.multirole-eng.com
Old 21-Jul-2009, 17:49
29psi rear & 30psi front would be a good starting point.
Old 21-Jul-2009, 18:08
Paul James's Avatar
Founder Member
Cheers Chris, I'm running the 180 rear rather than 190 as the bike handles better on this set up. Pressures still OK for that?
Old 21-Jul-2009, 18:18
Certainly will be.
Old 21-Jul-2009, 18:56
Bionicle's Avatar
Bionicle Bionicle is offline
For what its worth I run 29psi rear & 30psi front on my 996 track bike, never had any problems.
Old 21-Jul-2009, 21:53
Paul James's Avatar
Founder Member
Thumbs up
Thanks guys, sounds like a good starting point!
Old 21-Jul-2009, 23:05
Paul, I'm 'shocked' that you didnt search for the guide that I posted on the board years ago about 996 suspension setup
Dont worry - it was so long ago I cant find it either - but I do know where I stored the original....
http://homepage.ntlworld.com/flsntl/...suspension.pdf
Its a 7Mb download and sadly only contains info on the std 996 & 996S, std 996 track pressures they list are 29R/31F, which I guess ties in with the above.
Drinks are now on you in the bar
Cheers!!!
Frank
Old 22-Jul-2009, 10:45
Paul James's Avatar
Founder Member
Cheers!!!
Frank
Jeez Frankie, that's a pretty thin excuse for ripping me up on the bar tab
Old 22-Jul-2009, 10:58
Ray's Avatar
Ray Ray is offline
Those settings from PB are for the poverty versions of the 996. Mr James has an r, almost the pinacle of the 916/996/998 series fitted with Ooooooohlins
29 rear 31 front wont be far away if its dry.
I find the bike doesn't feel right on the lower than road pressures until the tyres have warmed up the pressures have gone up.
Does anyone have any "target" pressures for warm/hot tyres from a reliable source?
Ray.
Old 02-Aug-2009, 17:34
smilo006's Avatar
smilo006 smilo006 is offline
Mood: I like my bike
i know it is metric but 1.9 front and 2.1 rear. Got this from a Ducati team racing at Oscherleben some time ago. Seems to be fine.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:02.
