Old 20-Dec-2009, 14:43
jamespedro28 jamespedro28 is offline
749s Engin Cutting Out Some Times
hi really strange .changing down through the lower gears and she cuts out[not always but sometimes] starts again straight away bumping of or starter.any body got some ideas.it ca be really annoying.
Old 20-Dec-2009, 18:00
You are gonna have to be more specific,....any other symptoms?
Any warning lights on the dash,....eg,the orange EOBD light?
When was it last serviced,and where?
These are the most common faults;
Front coil breaking down.
Fuel pump relay.
Poor fuelling set up.
Old 20-Dec-2009, 21:05
749s Cutting Out
In Reply She Was Seviced Aprox Twelve Months Ago .since Then It Has Doon Some 2000 Miles .and Serviced By Moto Forza Italia.also It Has Doon 8500 Miles ,strangley Enough When Tring To Start Her Yesterday Morning After Beeng Stud For A Week The Eobd Light Came On And Stayed On For A Lot Longer Than Normal .but When It Eventually Started It Went Of. Ps It Wouldent Start With The Choak Leaver Pulled On .thankes For Your Help Pedro.
Old 21-Dec-2009, 09:27
Well the orange light is not staying on,....thats a good thing.
As for the engine cutting out,it could be something simple like the recent change of ambient temperature,....my 999 used to cut out a bit in cold weather,....or it could be the fuelling wants setting up again.Sounds like you must be due for another service.
Old 21-Dec-2009, 18:40
its me's Avatar
its me its me is offline
Hello,
If you search the Ducati forum sites you will discover some are prone to this.
Mine did and was sorted by a specialist (Ducati John) in 5 mins with his lap top.That was 2 years ago.
Recently I had to have another ecu fitted and guess what it did it again. Sorted once again in 5 mins with his lap top. I think its the TPS (sensor)
Good luck.
Old 21-Dec-2009, 18:45
Not having a 749, but could it be a case of the TPS needing resetting, I know they need resetting if you swap ECUs but how are they affected by either battery removal orbattery volts dropping below a certain level.
As 'Its Me' also suggests checking the TPS I would get along to a Ducati specialist and have it checked/reset
Old 21-Dec-2009, 22:31
The unfortunate thing with a T9/749 TPS, is they are not adjustable physically. They are part and parcel of the throttle body. The TPS on these has to be zeroed out using Ducati Mathesis equipment.
Old 22-Dec-2009, 16:57
749 cutting out
thanks to everybody for going to the trouble to sort me out .i think i will have to go to leeds .to see the ducati man .i am sure i will have more questions in the future .as i am relatively new to ducatis .thanks again, pedro.
Old 24-Dec-2009, 13:35
battery
hi said it would not be long before i would be back.would taking the battery and housing of send the datatool alarms of on one .as i think i need to remove them to replace some of the coolant hoses .
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:20.
