  #21
Old 24-May-2004, 17:32
nathanhu's Avatar
nathanhu nathanhu is offline
Mood: head down
chillo how heavy are you?
i had this weave or pump at high speed so if you weigh over 85 kg(dry) then go for the new spring on the rear it worked for me and cost very little
  #22
Old 24-May-2004, 19:08
jk2's Avatar
jk2 jk2 is offline
I have a 999S biposto spring (6Kg I think) which is too hard for the road - probably OK for track. Like new, £30 only!!ink:ink:ink:
  #23
Old 25-May-2004, 13:13
chillo's Avatar
chillo chillo is offline
Nathan
i'm 80kgs ish
i was going to dial in a bit of compression to see if that helps then i might give the new spring a go
chillo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:14.
