Old 24-Apr-2012, 18:54
steeevvvooo's Avatar
steeevvvooo steeevvvooo is offline
later wheels
When fitting a later rear wheel to an older monster, what do I need?
I assume discs, sprocket carrier etc are all interchangeable, so do I just need a new spindle and bearings?
Are later front wheels a straight swap?
Old 24-Apr-2012, 22:16
Steve the rear wheel depends on which model it is from. if its out of a Supersport or a 2001 600 Monster it probably has the same bearing and spindle sizes and would drop straight in. Later wheels from a 620 Monster (Not Supersport) uses a bigger rear spindle
Later front wheels use the bigger 25mm spindle so use different bearings and bearing spacer as well as speedo drive (or Spacer) so aren't a straight swap
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:24.
