Old 23-Apr-2012, 23:52
I've been busy...
...but what a pain that was!!
Old 24-Apr-2012, 06:38
Ooooh, get those tubes
Old 24-Apr-2012, 22:36
Shouldn't they be red for Hot water, then again if its going to sit in the garage Blue will do
Old 25-Apr-2012, 07:22
MJS's Avatar
DSC Member MJS MJS is offline
Bikes: None at the moment
Mood: Feeling old...
Clearly I should get some blue ones for mine as well
Old 25-Apr-2012, 13:40
bikercub's Avatar
bikercub bikercub is offline
Bikes: 748 Monoposto 01
Mood: ?
Kinda shame you cant ride with the fairing side on tho
Old 10-May-2012, 10:25
Managed to get some time in the garage this weekend and swapped the forks over. Luckily I've done this before on the DD bike so it took less than an hour start to finish.
A quick snap - the old calipers are still on the brake lines and the new calipers are in a box waiting to be fitted in this pic. I've converted the front wheel to run the 996R disks and it all lines up fine.
Next job is to get some spacers made up for the front wheel... but I've noticed that the banjo bolts on my brake lines are all corroded so I'd like to replace them as well...
Old 10-May-2012, 11:22
khu996's Avatar
khu996 khu996 is offline
Ant, are you using the original 748 wheel?
Did you have to use some special spacers to get it all to line up?
Old 10-May-2012, 11:28
Yes, I'm using my original 748 wheel but with 996R disks (15mm offset) instead of the original disks (10mm offset). This means that the wheel and disks all line up properly on the axle, but I just need to make up some spacers to sit the wheel in the right place. You could use 5mm spacers on the wheel, but a pair of disks came up cheap enough instead!
I've picked up a couple of oem spacers and will be turning them down to get the right spacing, but will post on here what that is one they're done.
Old 10-May-2012, 15:19
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
Let me know when you want me to put them in the lathe then!
Old 11-May-2012, 00:18
khu996's Avatar
Top man! I look forward to reading about it and seeing the finished pics!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:51.
