Old 09-Dec-2012, 09:16
dunlop0_1's Avatar
M600 wet to dry clutch conversion MK2
Ok there is no particular advantage to doing this but we all like a challenge. LOL
At the beginning of 2010 I undertook a wet to dry clutch conversion on my 620 DD bike. I had great success with the exception of creating a leak free seal between the output shaft and the clutch push rod. Although I raced all year with the conversion it was prone to regular oil/leak seal changes.
I decided the time had come to have another go at a MK2 version.
I picked up a later 600 motor off steeevooo one of the forum users (Bradders old bike) as Louise’s M600 is the earlier wet clutch version and cannot be converted.
The conversion is (reasonably) straight forward as regards parts,
1. Matched pair of dry clutch and crank gears (and the oil pump gear if yours does not match the crank gear)
2. OE dry clutch casing
3. 1mm thick spacer for behind the clutch gear
4. OE dry clutch spacer for behind the clutch drum
5. OE dry clutch basket
6. OE dry clutch plates (stacked accordingly)
7. OE or after market dry clutch pressure plate
8. Dry clutch alloy racing or after market drum. This needs to be so as the original multi part dry clutch drum will not fit the wet clutch output shaft. You ca use the wet clutch drum and pressure plate however, the pcd of the wet clutch basket spring mounting points are different to the dry clutch which prevents the use of an after market pressure plate. The drum centre also needs to be turned down to a depth of 15mm allowing the retaining nut and locking washer to fit.
9. New longer push rod (had to make this)
10. The oil seal. Now some of the 620 motors have an Allen bolt behind the sprocket which enables you to block off the oil gallery to the clutch by fabricating a blank. The alternative (in my case) was to create a better designed seal around the push rod. This seal would also have to support the push rod when the clutch is open (the OE dry clutch has a small bearing and seal in the end of the output shaft). I was able to purchase a 12x8x3 Viton oil seal for £3. I machined an aluminium plug which retains the oil seal and is an interference fit into the end of the output shaft thus giving support to the push rod when the clutch is open.
Finally there is a small oil gallery in the output shaft which I blocked off with plastic metal
Unfortunately I did not take any pictures on assembly. However, the basic drawing gives you the general idea and after the bikes first outing next year I will be dismantling the clutch to inspect it and I will take some then.
Hopefully the new seal design will be more robust than the one I used last year.
Old 09-Dec-2012, 10:29
Even a fellow Northern numpty like me understood that.
Old 09-Dec-2012, 11:03
Nice one Neil
did you treat Toni to a Slipper dry clutch or just the standard one
Old 09-Dec-2012, 14:53
dunlop0_1's Avatar
Nice one Neil
Standard Kev, non of that jiggery pokery up here.
Old 09-Dec-2012, 18:24
Chaz's Avatar
Chaz Chaz is offline
Bikes: 916 Strada
Mood: www.od2racing.co.uk
I did the one one my 800 last year even machined the end of the shaft to take a needle roller to support the clutch rod, only did it for the bling factor, then saw all the problems the 848 challenge guys were having spewing oil! So I converted the 800 back to a wet clutch far more reliable & much less maintenance! Shame about the bling though
Old 09-Dec-2012, 20:11
dunlop0_1's Avatar
Ah my learned friend. I have an 848 in my garage with a dry clutch and no oil leaks. Would'nt you like to know how?
Old 09-Dec-2012, 21:05
Chaz's Avatar
Bikes: 916 Strada
Won't leak in the garage mate! Even the likes of Mike Edwards & james white had the problem! Can't see any reason to run a dry clutch!! Although I love the sound & the look & would always run one on my road bike
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:00.
