  #41
Old 31-Dec-2013, 16:09
milesaway's Avatar
Bikes: 900ss 600ss xr400
Originally Posted by Campo
Talking about the fuel tank breather. The actual breather nipple on my tank has come loose and is able to be pulled away from the tank only slightly but has anyone had the same problem and got any tips on how to do something about it.
Or is it not a problem and I shouldn't be worried about it? I keep thinking it's going to completely pull out whenever I disconnect the pipe to lift the tank up
sounds a bit tricky- finding anyone who'll weld or braise it unlikely as an empty fuel tank+flame=bomb- maybe some of the tank seal putty stuff or liquid metal possibly???
braising probably best job if someone willing to do it after inside tank steam cleaned- would need a respray after though
  #42
Old 31-Dec-2013, 17:36
Campo's Avatar
Campo Campo is offline
Bikes: Class B 600ss #99
Thanks Miles I think I,ll try some sort of bonding compound. I did try and build up a bit of body filler round it last time I painted the tank but it eventually broke away
  #43
Old 03-Jan-2014, 09:11
Trumpet Trumpet is offline
Bikes: Triumph Speed Triple/DD 620/
Mood: It's a grand life if you don't weaken
I fixed a leaking tank with a compound called JB WELD, it is the only one the fuel did not break down. Not expensive and you can get it from Halfords etc. Should do the trick.
  #44
Old 03-Jan-2014, 18:35
Campo's Avatar
I will give some of that a go.
  #45
Old 07-Jan-2014, 19:42
Jonzi Jonzi is offline
Bikes: Monster 796, Class B 600ss
Evening
Where abouts can I get the right sized bolts to blank off the neutral switch and oil thingy?
And as I don't have a mechanical rev counter, does the spinny thing needs to be removed and blanked as well?
  #46
Old 07-Jan-2014, 20:56
milesaway's Avatar
Originally Posted by Jonzi
Evening
blanking bolt for neutral is a m8x 1.0mm pitch about 16/20mm long and a copper or alu washer- probably have to buy longer 1 and cut it down to length of switch- not sure oil light size as i decided put in brand new sensor instead- any metalwork supplier or maybe ebay
  #47
Old 08-Jan-2014, 20:25
Oil Pressure switch thread is M10 X 1.00mm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:35.
