Old 19-Mar-2014, 15:53
custard749's Avatar
custard749 custard749 is offline
1098 Rad leak
Hi guys
My 1098 is a 2007 with 17,000 miles on it and it has just had its rad fail.
Yes, the normal place they always go, top left hand corner under the bracket.
I have found a radiator company that will re core it for me for £230 as apposed to paying £635 from Ducati.
My problem is though it could happen again due to it being the same radiator, so was thinking of beefing up the bracket at the top left.
Has anybody else done this???
Old 25-Mar-2014, 05:52
Bionicle's Avatar
Bionicle Bionicle is offline
Have you checked with your local Ducati dealer if they will replace your rad under warranty ? mine went outside the warranty period but as it is a known fault it was replaced FOC,
Don't think you need to beef it up though as they changed the rads when they became aware it was an issue.
Old 25-Mar-2014, 06:54
dunlop0_1's Avatar
I'm not familiar with the 1098 fault but I usually tig weld the aluminium ones like the 996.
Old 31-Mar-2014, 14:54
Clippy's Avatar
Clippy Clippy is offline
Bikes: 1098
Mood: Enjoying a REAL summer!
1098 radiator leak
Mine did this at the end of last year and faced with the options of replace at silly money or re-core at half the silly money I took the advice Kempston Radiators in Bedford and allowed them to seal the top tube on the core which is the one that always splits.
There should, according to them, be no further leaks - they've done a few of these over the years and have never seen one come back - and it cost less than 60 quid all in including a re-spray to make it look smart again.
This will, of course, have reduced the cooling capacity of the rad, but the argument was that this wouldn't really matter much at speed, and when stuck in stationary traffic the top tube is not covered by the fans so shouldn't make a huge difference at the point where the bike is likely to get hottest.
We'll see how things go as the weather warms up...
Clippy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:35.
