Old 02-Nov-2014, 21:23
DangerousD DangerousD is offline
Bikes: Hypermotard 1100s
Hyper clutch alternatives - what fits?
evening all,
Rumour has it that the 'dry' type clutch packs are largely all interchangeable irrespective of model/series, can anyone confirm this?
DD
Old 02-Nov-2014, 21:53
Pretty much so, I fitted a oem 748R slipper clutch to my 2009 Monster 1100 DS
I see there is one of these on Ebay at the moment for £299
Old 03-Nov-2014, 08:26
Apparently the spring caps are different (deeper) like the 1098 to reduce lever pressure.
You may want to double check and possibly reuse your original spring caps if they are different.
Old 03-Nov-2014, 14:38
Spring weights/lengths have changed to. That's the main reason the cap dimensions have altered. Long spring with short cap leads top spring locking out..
Old 03-Nov-2014, 14:39
So reuse the original springs and caps and you should be good!
Old 03-Nov-2014, 17:38
I would have thought Spring lengths and Cap lengths should be matched to the Post length of the Back plate, so if fitting a 748R Slipper clutch it's probably best to fit the whole lot
Old 03-Nov-2014, 19:53
shhhh don't say it too loud.
Old 04-Nov-2014, 21:27
So, looking at the one on the bay of evil, it's a 'ramp' style, but how do these compare to the 'bearing' style?
What was in my 749r as I felt that one worked OK for me
DD
Old 04-Nov-2014, 21:35
I have 748R ramp ones in my 996 and my M1100 and bearing ones in my 998R and my 998 Hybrid and find there is little difference, once you get the end gap set correctly
Old 07-Nov-2014, 20:24
Ahhhhh, bloody well missed it. Stuck in a meeting and couldn't get to a PC
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:12.
