If you have the hand book it tells you the standard settings in there. :P
  Shock absorber adjusters (900)
 The Öhlins shock absorber fitted to the 900 model
 features also length adjustment. It allows to adjust the
 seat height regardless the spring preload.
 • Compression damping adjuster (1):
 14 clicks.
 • Rebound damping adjuster (2):
 10 clicks.
 Undo lock nut (3) and nut (4) to change original setting.
 STANDARD spring length:
 160 mm  This is taken from the manual.
 There's a few downloadable manuals on the ducati site:-
http://www.ducati.com/bikes/manuals.jhtml  Hope that helps mate. I can always swop ya a perfectly set-up showa.
  Steve
 [Edited on 2-9-2004 by tont2002]
