Old 26-Apr-2012, 23:20   #1
jangol jangol is offline
Bikes: 1098s, 749
Wanted Seat Cowl For 749/999
After a good bargain to spruce up my 749
Thanks in advance
Regards
JA
Old 02-May-2012, 12:08   #2
900MAN 900MAN is offline
900MAN's Avatar
Mood: 900 went 999 gone, Multi came and went, 749 Nero now
Your inbox is full
Old 03-May-2012, 21:36   #3
Bikes: 1098s, 749
Thanks, Cleared it down now!
Old 06-Jun-2012, 23:44   #4
Bikes: 1098s, 749
Still after a Cowl for my 749 BP... Any Takers
Old 07-Jun-2012, 11:04   #5
swannymere's Avatar
Mood: High as a kite!
Hi, You'll need to be a little more specific, do you want?
a) A genuine Mono (single) seat unit? In which case you'll also need a mono subframe (do some research as the subframes can crack). Starting around £250 on eBay for bodywork and subframe. You can cut up a biposta subframe, but that seems a bit of a faff to me.
b) A replacement Biposta (twin) seat unit to replace you're knackered one?
You can pick them up cheap on eBay
c) You want the mono look but not the expense? You can get Mono looking seat units which fir onto the Biposta subframe. Starting around £75 but more likely double that.
d) You can get a plastic replacement for the passenger seat pad to achieve the Mono look without much effort. Cost from £50 again more likely double that.
Old 07-Jun-2012, 13:13   #6
900MAN's Avatar
This looks the best cowl option but not cheap.
Offer Him £100 inc postage
http://www.ebay.co.uk/itm/DUCATI-999...#ht_1109wt_922
Old 08-Jun-2012, 09:09   #7
Bikes: 1098s, 749
I'm after a cheap (yes I said cheap lol) cowl to fit in replacment for my pillion seat...
I'd be interested in option c:/ any pointers for that would be great.
900MAN, tried the £100 but got no joy... so back to the drawing board..
Thanks for the heads up
Old 08-Jun-2012, 09:44   #8
900MAN's Avatar
Seen cheaper units but don't seem to have the fittings etc
This looks a possible option
http://www.hcracetech.co.uk/80720/info.php?p=3
Old 08-Jun-2012, 09:58   #9
Bikes: 1098s, 749
Thanks, these could do it. I will see if I can find anything a tad bit cheaper if not then it will be these..
Thanks as always
Old 08-Jun-2012, 10:05   #10
900MAN's Avatar
Don't think there is cheaper to be fair, be interested in how you get on
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:18.
