Old 06-Sep-2004, 18:13   #1
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
MOT Failure
Just had the ST4s in for it's first MOT today. Failed on 2 counts:
1. Front wheel bearing.
2. Headlight beam too high.
1. I can accept, the bike has done 12300 miles.
2. The headlight has not been touched since build. Also I had the front suspension dropped by 10mm when I first got the bike, so it must have been way out when delivered. Worth bearing in mind if your bike is due it's first MOT.
Old 07-Sep-2004, 10:02   #2
PaulC PaulC is offline
Did they have to fail it on the headlight beam??? You would have thought any half decent assessor would have just got out there trusty screwdriver and lowered it appropriately - all of 5 seconds work! Just noticed the front bearings on the ST2 are gone, any idea if aftermarket bearings are cheaper/better or just go with the OEM??
Old 07-Sep-2004, 16:31   #3
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
The bearings have reference Nos stamped on the sides (e.g.6005). Note the numbers and go to your local bearing supplier. They are usually much cheaper. I'm surprised at them only lasting such low mileages, the ones on my SS have done over 30K and are still OK.
Old 07-Sep-2004, 17:01   #4
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
I'd say definately go to a local bearing shop. They're dirt cheap by comparison and at least as good. The bike shop tried to stitch me for over £20 a side for wheel bearings on t'blade, but a local engineering shop had same spec on the shelf for £5!
As for the lights.... couple of years back my jap thing failed on light aim. The dude just wanted to send me away with a failure sheet! After much foot-stamping and arm waving, he adjusted them for FIVE QUID!!!
Old 07-Sep-2004, 20:32   #5
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
bearings are pretty cheap i think?
had both the front and back done
think there about £8 each
don't think these were
nelly sorted out the rear set when they failed near nottingham, on the way to cadwell for the track day.
and a few weeks kater mike davis did the front when i had some new tyres fitted.
just coming up to 16k
Old 07-Sep-2004, 20:54   #6
My ST failed through having a faulty rear brake light switch (OK, fair cop, it had seized 'cos I never use the back brake).
But... it also failed through having a loose petrol tank The assessor wouldn't listen, wouldn't take the tank pad off and look for himself, I had to take the tank pad off when I took it back in to show him that the rear of the tank has a pin hinge and the front is held down by a rubber strap
Old 08-Sep-2004, 09:45   #7
Blimey Jools!
I dont think its quite a five minute job to adjust the headlight though - i think the top fairing has to come off. To someone who hasnt done it before that could take a while to do.
My old Skoda's MOT was due in December and everytime it used to fail cos the windscreen washers didnt work. The engine was in the boot and washees never got warm enough to unfreeze. Aditives just were not strong enough without the extra warmth of the engine. I used to take it home and pour a kettle of hot water over them then go straight back.
On my old Mini they also let me sit in the car while they tested the brakes. Hand brake was a bit iffy so i'd be pulling with two hands on the lever while putting my whole weight on the pedal as well.
Old 08-Sep-2004, 10:34   #8
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Height adjustment needs nothing removing - sit on the bike, 8mm socket on a driver & twiddle....
Left / right, you need to remove the right hand grey panel adjacent to the clocks to get at the adjuster.
Maybe seven minutes is more realistic...........
Old 08-Sep-2004, 11:09   #9
Fair enough! Still, if you didnt know about it...
Old 08-Sep-2004, 18:32   #10
chrisw's Avatar
MOT Pass
Am now street legal and £80 light of pocket (Inc MOT fees).
Here are a few new MOT regs that came in this year.
1. Number plates:- Have to be square with letters and numbers of equal dimension and spacing, in two rows. Letterbox number plates will result in a fail. There is no size stipulation for the plate, just that it is square. The letters and numbers on the plate must be of equal thickness.
2. Frame numbers are now also part of the test. It is a requirement that the tester checks both the frame number and vehicle identification (VIN)
3. Fuel system:- detailed check for any sign of fuel leakage or patched up work on the fuel delivery system. Any bodging = fail.
and finally a little snippet about exhausts.
The exhaust system must be complete, secure and not too noisy (and that is for the tester to interpret). The exhaust must not have any markings like "Not for road use" or "Trackday use only". However, if such markings were to be accidentally covered by a sticker then the tester is not allowed to remove said sticker. They are not allowed to alter the bike in ANY WAY whilst conducting the test.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:05.
