Old 08-Sep-2004, 18:48   #1
Albie Albie is offline
Albie's Avatar
M900 rear shock
Got a badly behaving rear. It bounces and jumps a lot even though the rides not firm. NBs thinks it may need refilling with gas but where can this be done ? Its the sachs type. its only done 8000 miles and is in vgc. Has anyone got a good one for sale maybe. Thanks anyway.
Old 08-Sep-2004, 20:02   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
...but what do I know albie!
To expand a little.... albie's shock has preload and rebound adjustment. The rebound seems to be doing nothing silly and responds to adjustment, but the compression is very soft with no means of adjustment.
I'm assuming the compression is controlled by the gas pressure... is that right? And does anyone know what pressure it ought to be at??
Old 08-Sep-2004, 20:30   #3
Albie's Avatar
Thanks for that Nige
Yes thats what I meant to say. Thank you Nicholas.
Old 03-Oct-2004, 09:18   #4
They are all like that I'm afraid!My wife swapped her '97 M750 for an '02 M900ie and the handling is just the same!
At 8k miles I doubt the shock is worn out.The rear end is fine for "normal" riding on A roads,but can get a bit vague when chasing 996's down bumpy back roads.
For the best results,we wound up the preload and then gave it a lot more of the rebound damping.About one full turn from fully in,if my memory is correct.The shocks are really basic and you cannot expect the same performance as the units fitted to the superbike range.
If you do really need a new unit,Hagons do some excellent shocks for not a lot of money.
Old 03-Oct-2004, 21:58   #5
Or.....
Here is a shock from an S4
Old 03-Oct-2004, 22:07   #6
Albie's Avatar
Will it fit mine though
Old 04-Oct-2004, 15:21   #7
As AK pointed out on another thread,it depends what frame you have.
If its the early 888 type with the rear hoop style ride height adjuster,the it probably wont fit.
If its the later ST frame with the rod ride height adjuster then it just might.
Hope that helps.
Old 04-Oct-2004, 16:02   #8
Albie's Avatar
It is the early frame 888 with the loop I'm afraid.
Old 04-Oct-2004, 16:36   #9
As I said before,Hagon Shocks are excellent value for money.
Fully adjustable,preload,comp,rebound and fully rebuildable.All for 255 quid.Not too shabby.
www.hagon-shocks.co.uk
[Edited on 4-10-2004 by KeefyB]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
