Old 08-Sep-2004, 21:08   #1
boyo boyo is offline
749r instability.
Hi guys having gone to assen wsb at the weekend a proplem that has bothered me from day one of picking the bike up reared its ugly head again, not all the time but when there seems to be a bit of a wind in the air the bike becomes very unstable from about 80mph onwards. The bike goes into a wobble/weave on the front end and sometimes at higher speeds is so bad that to throttle off seems the best option, i know today in msn the 2005 models are loosing some vents but i need to know if anyone else is getting this proplem and if thay have managed to do anything to rectify it. I had a 748 before this and never once experianced anything like this.
Old 08-Sep-2004, 21:12   #2
Wheres your steering damper set to?
Old 08-Sep-2004, 21:20   #3
Felix Felix is offline
I doubt it's the steering damper if it's a low frequency weave. Try raising the rear ride height/pre-load, or drop the front. More often then not, it's caused by not enough weight over the front. How heavy are you?
Old 08-Sep-2004, 21:32   #4
butch890 butch890 is offline
Mood: Enjoying Togdom !
What tyres is yours on?Mine is on diablos and although my damper is wound right off mine only has tiny bit of wobble,mainly in turbulant air following lorrys.
Did the dealer you bought it from set the bike up to suit your weight and riding style?
Old 08-Sep-2004, 21:33   #5
Thanks for replying guys, right the steering damper is set on 4clicks clockwise and i weigh nearly 15 stone plus my leathers, i have not touched any settings on the suspension at all.
Old 08-Sep-2004, 21:35   #6
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
boyo,
i live in germany ,land of the autobahn, my 999s hits the rev limiter in top and shows 282 kph , ive never had a problem with instability or weaving ,just buffeting from the wind as its hard to get out of the airstream at high kph
Old 08-Sep-2004, 21:37   #7
Boyo, check the rear suspension setup. This can almost certainly be tuned out by suspension adjustments.
Old 08-Sep-2004, 21:40   #8
Murray Mint's Avatar
My out of the box 749s needed the rear sag to be reduced by over 10mm, dont sound much but it nakes a difference.
Old 08-Sep-2004, 21:42   #9
the bike came with michelin pilot race and iv just put avon azaros on to go to holland, the proplem is the same with both tyres.
Old 08-Sep-2004, 21:46   #10
Loz Loz is offline
Loz's Avatar
My 999S rear suspension was not at the factory standard settings when I bought it. Compression damping was about right, but rebound was wound up big time! It didn't unduly affect my handling, but it's worth making sure they are at the factory standard, to start with.
Also, make sure the tyres are correct make/size/pressures for the 749R.
Agree with Felix, probably not a steering damper issue at all.
749/999s seem susceptible to crosswinds (in my opinion) but this should manifest itself as a desire to change direction, not a weave or wobble.
My two cents (nearer three, probably)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:15.
