Old 09-Sep-2004, 11:38   #1
DeeJay DeeJay is offline
Cutting out/bad idle
My 748 sp has started to miss and splutter on tickover. When it's cold this results in it stalling and when warm just alters the idle rate. The bike hasn't been used too much of late but has just had a mini-service (oil, fuel filter etc).
The bike's relatively new (to me) but the power delivery feels very 2-stroke like (i.e weak until 7k rpm when it takes off). I'm not sure whether this is a symptom of the same problem or just a characteristic of the wilder cams on the sp.
Could anyone offer any suggestions as to what this could be or should I be booking it in at the local dealer?
Thanks in advance.
DJ
Old 09-Sep-2004, 11:56   #2
748mart 748mart is offline
Did you change the plugs as part of the service?
Old 09-Sep-2004, 13:16   #3
I believe so (I'll check the receipt). I was thinking that the HT leads breaking down could possibly cause this. It could tick over nicely for 20-30 seconds then misses about 5 times in the next 30 seconds so it's not at all predictable.
I actually plan to have it blueprinted and given a 'full monty' service over winter which should sort but just want to have some fun whilst the sun's shining!
D
Old 09-Sep-2004, 13:35   #4
desmojen desmojen is offline
Mood: DOH!
The power band thing is quite normal mate, mines the same!
Have you got the right chip in for your exhaust? Mine was terrible when I got it and that was why, but having said that mine is reminiscent of a bag of nails at tickover too.
Old 09-Sep-2004, 15:12   #5
I need to check the chip really (or change the exhaust back for a day). Someone mentioned getting it RR'd and mapped correctly so I may do that, but just wanted to make sure I wasn't going to have to spend a fortune sorting this problem out first Is the chip easy to get and/check it's non standard?
thanks,
D
Old 09-Sep-2004, 16:29   #6
Mood: DOH!
Yep, it should have a code on it, you just ring one of the specialists (JHP or someone like that) who should be able to tell you if you have the right one or not.
Could be also that your tickover is just a tad too low?
Old 09-Sep-2004, 16:49   #7
Mr_S Mr_S is offline
There was a thread on here a month or so ago with all the chip codes on them and what they should have been fitted to.
In fact it's here
http://217.199.188.40/xmb/viewthread...=9814#pid79924
Jason
[Edited on 9-9-2004 by Mr_S]
Old 09-Sep-2004, 17:05   #8
I don't have plaster restricting my typing though :P
Old 09-Sep-2004, 17:39   #9
Thanks guys! I don't actually think it's the chip though! I've just had it start with the 'choke' i.e 2k revs and you can still hear it missing occasionally.
I'll check the chip regardless, but this has got to be something to do with fuel/spark surely?
D
Old 09-Sep-2004, 18:11   #10
Mood: DOH!
What do you think the chip does? Lol
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:19.
