Old 02-May-2012, 00:17   #1
9one6 9one6 is offline
Bikes: 916, 860, 1982 & 83 Katana's
9one6's Avatar
Mood: always good
916 No start
I'm having a problem with my 1998 916 Mono. Has been running great up to last week. Tried to start it today and won't start. Checked a few basics such as fuel, fuses, battery, compression, connectors etc..
Engine does turn over fine. The fuel pump does energize when key is turned on but there is no spark and no fuel injector pulses. I am suspecting a problem with the 1.6M ECU or some type on crank sensor that is not sending a signal to ECU.
Any information on diagnostics would be appreciated.
Thanks,
Enzo
Old 02-May-2012, 06:36   #2
dunlop0_1's Avatar
Does it have an alarm?
Old 04-May-2012, 06:40   #3
9one6's Avatar
Mood: always good
916 no start
Hi.
Actually I'm not sure if it has an alarm. I don't see one. Did they come with some type of anti-theft system from the factory or are you talking about an aftermarket unit.
Old 04-May-2012, 12:05   #4
Cobbett Cobbett is offline
Bikes: 750ss, 998s
Cobbett's Avatar
Aftermarket. So, do you disarm an alarm with a fob before you ride it?
Old 08-May-2012, 04:24   #5
9one6's Avatar
Mood: always good
916 no start
No do not have an aftermarket alarm. There is no alarm. Would like to check the gap on the crank sensor. Is this an easy procedure?
Old 18-May-2012, 03:53   #6
9one6's Avatar
Mood: always good
916 no start
Well I found the problem with the no start condition. Would you believe a faulty neutral safety switch. The neutral light on dash was working properly. Engine would crank over fine and fuel pump energized when key was turned on but then no spark and no fuel injector pulse when cranking. Go figure?
Starts great now.
Enzo
Old 20-May-2012, 22:14   #7
9one6's Avatar
Mood: always good
916 wiring schematic
Does anybody know a good free site that I can download wiring diagrams for my 916 ?
Old 20-May-2012, 22:25   #8
Thunk it's carlsalter.com or something like that I got mine from
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:56.
