Old 17-Sep-2004, 11:48
Wot no \'SS\' posts
No posts for TWO days !!!
It aint right....ahh or maybe everyone is out riding
Anyone care to tell me the easiest way to change a sprag clutch - AND DONT SAY "CHANGE THE ENGINE / BIKE" !!!
Frank
Old 17-Sep-2004, 19:53
FiscusFish's Avatar
Er, pay someone else to do it...?
Old 17-Sep-2004, 21:00
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
have you thought about changing the engine/bike
sorry but you asked for that
by the way i don't even know what a sprag clutch is??
any clues
Old 17-Sep-2004, 21:43
Ok Glyn, yep I did ask for it didnt I
From my feeble understanding the sprag clutch is on the other end of the starter motor and is the the link to the engine - problems with the clutch can appear to be battery / starter motor faults but are actually down to the 'mini' clutch.
Cheers - Frazzled Frank
Old 18-Sep-2004, 17:10
kwikbitch's Avatar
I thought that the spragg clutch was different to the "norm" in that it made the gear change smoother due to the instant pick up of the fly wheel...it is actually used on Gym equipment at our school and Nelly showed me a new one ages ago...(could be wrong though and the terminology is probably completely incorrect AND I'm sure someone will be along to put me straight ...After all I have a head like a sieve and I am a woman!)
Old 19-Sep-2004, 01:21
To change the sprag clutch you need to pull the lhs engine casing and remove the generator/flywheel assembly.
It's not that difficult, but you will need a puller of sorts to remove the cover and a tool to hold the alternator rotor.
Also, check the driven gear where the sprag bearing runs. If that's worn, the new bearing will wear out pretty sharpish.
Lisa..................another blonde moment me thinks
Old 19-Sep-2004, 02:17
Cheers Nelly,
I only had the starter motor pulled out and rebuilt last year, so I'm a but reluctant to do the job until its absolutely necessary.
Would leaving the job entail any possible damage at all?
Many thanks - Frank
Old 19-Sep-2004, 11:05
Frank, if the bearing itself is starting to fail, then it could damage the contact surface of the driven gear.
The sprag bearing isn't cheap, but the driven gear is even more. About £140 if I remember right.........
  #9
Old 19-Sep-2004, 11:15
kwikbitch's Avatar
:P:P:P
Well I tried...Can't be brilliant at EVERYTHING!
  #10
Old 03-Oct-2004, 12:25
SSTU SSTU is offline
Hi Frank Im sure there's a web site that tells you how to change
the sprag just type (sprag clutch) on your search engine. I remember looking at the site when I had problems.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:20.
