Old 18-Sep-2004, 19:17   #1
mutley64 mutley64 is offline
Mood: Where'd the summer go
Tyres
Hi peeps,
can anyone help? What are your suggestions for good all round tyres for my 748? I need to get the confidence up a bit and am at present running mismatched tyres. Advice from the Mille lads have told me to put a pair on - and yes i know they are right - but which ones?
They need to stick to the road like nobody's business and good in the wet - not that I ride in it - may get caught in it now and again.
Thanx
Mutley
Old 18-Sep-2004, 19:22   #2
Dementor's Avatar
BT 010 for me every time
Old 18-Sep-2004, 19:23   #3
I'm a Pirelli Corsa fan (I run SuperCorsa's which I wouldn't recommend for road riding in the wet)
I've heard that Bridgestone are the go in the wet, but I've never tried them.
More Bridgestone fans?
Old 18-Sep-2004, 19:25   #4
Mr_S Mr_S is offline
Pirelli Diablos, not the Corsa ones as they're cr@p in the wet.
Old 18-Sep-2004, 19:26   #5
Mood: Diet
I like Pirelli Diablo's or Diablo Corsa's. Both are excellent, loads of grip. The Corsa is more track focused and not quite as good in the wet (but still better than a lot of other makes)
Rob
Old 18-Sep-2004, 19:43   #6
keefer keefer is offline
keefer's Avatar
i dont go out if it looks like rain so i run rensports [not much cut]
if you intend to go out on the bad days ie most of the time, then go for the BT010's its a very good tyre
[Edited on 18-9-2004 by keefer]
Old 18-Sep-2004, 20:14   #7
Standard Diablo`s, a cracking tyre, can not fault them
Chris.
Old 18-Sep-2004, 20:38   #8
desmojen desmojen is offline
Mood: DOH!
BT010's are v.good, I ran mine on BT012ss's, they were spot on!
Old 18-Sep-2004, 23:00   #9
psychlist's Avatar
Mood: Lucky? For some, maybe!
BT010 every time!
Old 18-Sep-2004, 23:44   #10
Thats because the Corsas have a lot less Silica than the normal Diablos
So my choices would be Diablos, Sportecss or BT010s in that order.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
