Old 20-Sep-2004, 23:56   #1
Totto Totto is offline
998 Clutch bits ?
Hoping to strip the clutch on my 998 again ! ,but this time pull the basket out ,is there anything strange i should know Nut size's would be helpful , i have pulled the plates out & cleaned twice already but this time is gonna be a full strip out in prep for a new clutch ( Slpper maybe !!!!!)
Thanks !
Old 21-Sep-2004, 12:55   #2
I think the clutch drum nut is 32 or a 34mm, I am pretty sure it's a 32...
The hardest bit will be getting that bugger off, dunno what the standard clutch torque setting is, but the slipper needs 195ft/lb torque from memory
Old 21-Sep-2004, 12:56   #3
Youll need a proper clutch drum holding tool!!
Old 21-Sep-2004, 13:10   #4
Made out of an old set of friction plates, a welder and a piece of bar.
Old 21-Sep-2004, 13:21   #5
32mm socket for the clutch centre nut and a 13mm on for the basket ones.
You'll need a holding tool as already suggested. Torque on the centre nut is 186Nm, the basket bolts are 33Nm(?) Use loctite on them all.
If you fit a slipper, depending upon brand, the new centre nut could be a 30mm jobbie.
Old 21-Sep-2004, 17:18   #6
Aint got an old set of plates !!! ,this will be the first set managed to get 7.5tho miles from the oe ones with regular stripping & cleaning !
Anyone got an old set no longer in use i could use to make a tool ,will cover any costs ????
Thanks for the help so far
Old 21-Sep-2004, 21:14   #7
748mart 748mart is offline
Here is a pic of my homemade clutch holding tool.
bar is aprrox 7mm thick x 20mm wide and about 3ft long
bolts are m6 countersunk heads
used qty 4 plates
[Edited on 21-9-2004 by 748mart]
Old 21-Sep-2004, 22:03   #8
redsp redsp is offline
Ive got some old plates kicking about if you still need some.....
Old 22-Sep-2004, 01:15   #9
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Nice looking tool 748mart. but it won't hold the basket. If you were to sandwich a couple of old frictonplates between them, then it would.
Toto I've a factory clutch holding tool you are welcome to use. The only problem would be the postage. It cost me £30.00 and it only travelled 10 miles or so. Its about 3 or 4 ks
Old 22-Sep-2004, 12:17   #10
Thanks all
Jon do you have any pics ,if i could get a lookie at it i might be able to make my own , if it looks possable then the pastage would not be a problem , failing that i could make one using old plates
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:19.
