Revised Rear Sprocket Flange Spacer
I am currently attempting to uprate rear sprocket assembly to the'998' type which does not have circlip.
I have placed new flange, renthal carrier and new spacer on shaft & have noticed the flange is sitting approx 3mm further out than standard flange.
To confirm there is a problem I have placed spacer & flange on flat table & this sits about 3mm higher than standard flange.
If anyone has these revised parts laying around could you possibly measure spacer thickness & or flange height.
old flange = 37mm
new flange, 32mm + spacer, 8mm = 40mm
therefore sprocket will be 3mm out of line & carrier will be loose.
Martin.
[Edited on 25-9-2004 by 748mart]
