Old 13-May-2003, 23:13   #1
pj748r pj748r is offline
Mood: FIVE!!!!Guess We'll Keep It
sidestand
does anyone know of a sidestand/wiring mod i can do to my 2000 748r so i can start it while its on the sidestand?thanks
Old 14-May-2003, 07:55   #2
Aotearoa Aotearoa is offline
Mood: Xstatic
http://www.evoluzione.net
Then go to the specials option ...$31.99 $us + shipping :P
Old 14-May-2003, 08:13   #3
Felix Felix is offline
MotoDesigns in York. 01904 623 421. Speak to Tim, usually in stock.
Old 14-May-2003, 09:49   #4
I'm making my own now to. £25 fitted or posted free
Old 14-May-2003, 14:59   #5
Mood: Xstatic
check the market place :P
Old 14-May-2003, 15:04   #6
Ray Ray is offline
Ray's Avatar
If you don't mind the potential to set off with the sidestand down. Remove the switch completely, unplug the connector and link the two wires together in the half of the plug that remains in the bike.
Linking the two remaining wires is vital and you need to make sure they stay linked cos the engine won't run at all if they are not joined.
The solutions mentioend by other above make so the engine will run but cuts as soon as a gear is selected/the neutral
light goes out.
Ray
Old 14-May-2003, 16:41   #7
BOLT BOLT is offline
Mood: Waiting for the Sunshine
test
Old 14-May-2003, 16:44   #8
I did this myself to my 998, and it cost 50p for the diode.
Procedure is to connect a IN4001 diode from the +ve side of the neutral light to the 'Blue' wire side of the sidestand, with the 'striped' end of the diode connected to the neutral light side.
This has worked well for over 12 months and for 50p, a real bargain.
This way means that the engine operates either when the side stand is up, or when both the sidestand is down and the neutral light is on.
hope this helps
Old 14-May-2003, 16:55   #9
DJ Tera DJ Tera is offline
I "modified" the switch myself for free when I chucked it down the road after hitting some diesel a few months back:P
Old 14-May-2003, 17:08   #10
Is that just an excuse to get a red paintjob ?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:49.
