Old 30-Sep-2004, 20:26   #1
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Magnesium wheel versus standard
Well..got the tyre fitted to the marchesini magnesium rear wheel today....talon are going to knock up a gold sprocket for it as the carrier is a five bolt fixing (apparently its a corsa fixing).
Couldnt believe the weight difference !!! The standard 888 wheels must be the worlds heaviest coz with the tyre on it takes 2 hands to lift (and its still a struggle!)..I can lift the new wheel/tyre combo quite easily with one hand !
So come on..let have some weight saving guesses for the new rear wheel setup..
Weight of the standard wheel/tyre/disc is 13.4kg...closest gets to pat themselves on the back !!
Nat:
Old 30-Sep-2004, 20:29   #2
sparkin sparkin is offline
sparkin's Avatar
On the corse bikes didn`t they have a larger wheel spindle on the rear wheel.
Old 30-Sep-2004, 21:11   #3
Nattyboy's Avatar
Early ones did apparently..but this is one of the last made apparently and as such, has the std spindle..??
Oh.and wheres your guess my laddo ??
Nat
Old 30-Sep-2004, 21:19   #4
keefer keefer is offline
keefer's Avatar
7.5kg
Old 30-Sep-2004, 22:31   #5
sparkin's Avatar
Are they 5spoke or 3spoke?
Old 30-Sep-2004, 22:54   #6
yeti yeti is offline
yeti's Avatar
4.5 kg
Old 30-Sep-2004, 23:16   #7
Nattyboy's Avatar
5's sparkin..
Old 01-Oct-2004, 13:23   #8
paynep's Avatar
Mood: Wet wet wet
"...std 888 wheel.. takes 2 hands to lift (and its still a struggle!)......."
I'm surprised you can pull the clutch in then!
Too much looking at glossy pictures, maybe?
I almost beat you to Celeste's wheels, but the aggro of getting two carriers made up so I can change gearing at the track quickly was too much for me - I'll just have to carry on with the cast lead ones.........
Weight of new setup depends how much rubber is left !
Cheers, Paul
Old 01-Oct-2004, 15:25   #9
I'll have a stab at 9.4Kg
Old 01-Oct-2004, 15:35   #10
8.1kg?
