Old 13-May-2012, 00:54   #1
pguenet pguenet is offline
FS - 996 / 916 / 748 Fairings elements (track / carbon / fiberglass)
Photos for all advertised parts available after listing
Complete front fairing assembly for Ducati 998 (fiberglass replica of RS02) – will fit 996 / 748 / 916 as well. (FIRST REFUSAL)
Nose cone
2 side fairings
Undertray
Fiberglass
Side panels have been layered with 2 layers of kevlar which will not wear through if the bike slides down the road. Not the cleanest finish by far but will protect your bike for sure.
The nose cone is in great condition.
The side panels are bit tatty – right panel has scraped a bit on lower edge
Undertray is tatty, rear ledge has been cut off, some exhaust burns.
If you want your bike to look perfect, look no further. If you don't want to hurt the pocket with track fairings that will protect your bike in a crash, those are good ones.
Looking for £100 for all nose cone / sides / undertray
Collection only from South London
Wide track Fiberglas mudguard - £50. (RESERVED)
RS wide track fitting / 40mm narrower mount for race forks.
Good track spare part so you don't risk your RS kit on track.
Carbon Fiber mudguard – standard fitting - £50
Looks like original Ducati performance – narrow track road fittings.
Very like – Carbon Kevlar reinforcements on the edges.
This has been however somehow recut in places for a more racing shape
Does not affect fitting.
A small crack on the bottom edge – see pictures
Fiberglass single seat unit with number boards - £40 (FIRST REFUSAL)
OK condition, some cracks around some fitting points
Fiberglass nose cone with number board - £40
OK condition for a track fairing.
Carbon airbox (RS originally, modified and tempered with, bit tatty) - £80
Carbon airtubes (bit tatty) - £80
Carbon v-piece with mesh oil cooler protection - £40
Carbon v-piece – small crack on bottom with epoxy repair – see picture - £30
Pictures supporting this advert:
Front fairing assembly - £100
Wide track mudguard fiberglass - £50
Seat unit with number boards - £40
Old 13-May-2012, 00:55   #2
Nose cone with number boards - £40
Carbon airbox – RS modified - £80
Carbon airtubes – bit tatty will need TLC to fit - £80
Carbon mudguard standard fitting - £50
Old 13-May-2012, 00:58   #3
Carbon V Piece with mesh protection - £40
Carbon V Piece with small crack - £30
Old 14-May-2012, 16:19   #4
stafford stafford is offline
Bikes: 888 Strada 888 Classic TT S2R1000 1000SS ST4S 900SSie M750 600SS
stafford's Avatar
Mood: Looking for speed
About to PM
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:18.
