Old 10-Oct-2004, 20:45   #1
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
o/t chip voltage
whats the correct core voltage for an amd athlon xp 2400+2.0ghz
Old 10-Oct-2004, 21:07   #2
Loz Loz is offline
Loz's Avatar
I'm no expert, but the link below indicates 1.35 V, unless I'm completely wrong. Which I usually am.
AMD XP 2400+
Old 10-Oct-2004, 21:43   #3
Glyn's Avatar
cheers
Old 11-Oct-2004, 20:59   #4
Glyn's Avatar
quick update
my puter kept crashing all the time
the chip ive got is ment to run at 1.65 volts(cheers loz but that one you looked at was a laptop chip lower power useage)
after being in contact with abit, who make my mother board it was suggested that i try upping the voltage to 1.725 volts. i have done this and everything is now running fine.
does any one else think this sounds a bit iffy.
Old 11-Oct-2004, 21:07   #5
Loz Loz is offline
Loz's Avatar
D'oh! Musta been tired.
Yes, definitely iffy. You absolutely sure which chip you've got?
Old 11-Oct-2004, 21:17   #6
Glyn's Avatar
yep says it on the box puter auto detects it aswell, also has been running quitee hapily in me old board for a year or so
puter also automaticly select right voltage aswell
luckily this is manually over rideable
Old 11-Oct-2004, 21:26   #7
Loz Loz is offline
Loz's Avatar
Weird. Upping the voltage is something you might do to over-clock the chip (if I understand things right).
It's at this point I bow out gracefully!
Old 11-Oct-2004, 21:58   #8
Be careful when upping the voltage as you will also increase the heat dissipation. You can check with something like Winbond hardware doctor which will monitor your voltages and temperatures.
Just be aware you might need some extra cooling.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:05.
