Old 11-Oct-2004, 01:15   #1
Redsps Redsps is offline
Redsps's Avatar
996 into 851, any possible probs to look out for.
Finally managed to get the 996sps engine rigged up on a test bed.
also got to the bottom of the electrical probs I have been having with it all week long, which has delayed it's fitting into bike .
Got it running , but it's sounds a bit lumpy to be honest, probably needs a service, although it has been tuned etc before with the previous owner.He quoted me 130+ bhp figures that he had got from it.
Now the question that has been stuck in my grey cells is this.
Will this be a straight forward swap over, there are bound to be a few oddities to overcome, but does anyone foresee serious probs ahead to overcome.
If so,what might they be.
The engine is complete with throttle boddies, cables, loom, etc.
Just need to be ahead of the situation in case it all turns pants.
Not quite sure what an 851 with 130+bhp will ride like though, might be an interesting experiance to say the least.
any info would be gratefully accepted.
If I get stuck, any chance someone can help me out.
cheers
robin
Old 11-Oct-2004, 08:09   #2
I may be wrong,but I think the crankcases are slightly diferant.Summat to do with the swingarm mountings.
Didnt someone else do this conversion?rob41b?
Old 11-Oct-2004, 09:53   #3
Mark Mark is offline
Mark's Avatar
Rob41b has got a 888 with a 996 lump.
Sweet looking bike as well.
I'll let Rob comment further
Old 11-Oct-2004, 10:35   #4
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
I think that might be right about machining the cases..and will you utilise the 851 rad...not sure a 996 one would fit..? I wouldnt worry about the effect of the extra power on the chassis..it was designed to cope with much more than that when they designed it for WSB...!
Good luck Robin..
Nat
Old 11-Oct-2004, 10:59   #5
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Robin,
Been there, done that, except the crankcases that drop straight in are the st4s type. You'll need to mod the cases to allow for the swing arm bearings and bore the frame for 12mm bolts. Other than that, it's all pretty much electrical mods that's be required to make things work. Electronic tacho, temp senders (minor detail) and other ods and sods. I have plenty of the Ducati type connctors and crimp tools so they can be made up from scratch.
Give me a call if you'd like to talk it through.
Rgds,
Rob
Old 11-Oct-2004, 11:05   #6
Nattyboy's Avatar
Ive got a fir bit of electrical stuff left in my stock if you need owt robin (temp sensors, looms etc)
Special rates to 8** enthusiasts...
Nat
Old 11-Oct-2004, 11:51   #7
Mark's Avatar
Nat
Ever the Del boy of DSC
Old 11-Oct-2004, 20:54   #8
Nattyboy's Avatar
you know it makes sense rodney..
Old 11-Oct-2004, 21:50   #9
Mark's Avatar
Is that you Dave?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:02.
