Old 11-Oct-2004, 14:14   #1
keefer keefer is offline
keefer's Avatar
ohlins shock
ok shock is out, so overhaul and new spring.
where should i send it
Old 11-Oct-2004, 14:18   #2
keefer's Avatar
any idea how much
Old 11-Oct-2004, 14:39   #3
Dukerob Dukerob is offline
Bikes: Diavel
Dukerob's Avatar
or Kais, they're also Ohlins experts Kais Web-site
Old 11-Oct-2004, 16:05   #4
Or Phone Richard at Harris Performance, about £90 for overhaul of seals oil etc and £60 odd quid for a spring last time I enquired, I get my springs else where fopr under £30 normally.
Old 11-Oct-2004, 18:11   #5
m1keyp m1keyp is offline
Maxton and get them to do the forks at the same time!
Old 11-Oct-2004, 20:18   #6
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Mmmmmm,
Im just about to get an Ohlins shock serviced as well. What is the weight range for a K tech spring with a number of 57-160-60?
I am about 14 and a half to 15 stone when fully kitted up in my bike gear.
Cheers,
DC.
Old 11-Oct-2004, 20:28   #7
Not sure but I think that means its a 160mm long spring rated at 6.0kg/mm which is very light if fitted to a 748/9**
Probably about right for a 10 stone rider
Old 11-Oct-2004, 20:34   #8
DC DC is offline
DC's Avatar
Oh bugger,
Looks like I will be changing the spring then.
And yes it is for a 748 but I have a single seat unit so no passengers.
Old 11-Oct-2004, 20:55   #9
From what I recall the single seat 748/9** bikes came with either a 6.4kg/mm or a 6.5kg/mm spring with the Biposto getting a 7.5kg/mm
Have you ever checked the loaded and unloaded sag to see how it compares to recommended settings.
http://www.ohlins.com/pdf/07241-02.pdf
page 5
Old 12-Oct-2004, 18:11   #10
DaveB916
Ohlins
Always send mine to Alan at AJR racing never let me down.
http://a.shirley.users.btopenworld.com/main_index.htm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:14.
