Old 12-Oct-2004, 13:14   #1
Green1 Green1 is offline
Green1's Avatar
Mood: 1098s...oh yes
Socket Size.......help please
Need to buy today ... can some kind person advise me on what size socket I need to get to enable me to loosen the rear axle so I can adjust the chain. On an 04 999r type swinging arm. Thanks v much
Old 12-Oct-2004, 13:24   #2
clint clint is offline
clint's Avatar
36MM TORQUE SETTING 180nm.
Old 12-Oct-2004, 13:26   #3
clint's Avatar
Sorry i may be wrong because its "r" version swing arm.
Old 12-Oct-2004, 18:12   #4
Not wrong
Old 13-Oct-2004, 09:20   #5
Loz Loz is offline
Loz's Avatar
I know I'm making a big mistake here, but why do you need to loosen the rear axle to adjust the chain on a 999? I just use the tension adjusters on my '03 999S.
I know I'm in for a kickin' now ...
Old 13-Oct-2004, 10:28   #6
Mood: going for a ride...
how can the adjusters move the rear wheel if the axle bolt is tight ?
I think you will find that you have been NOT adjusting your chain tension
Old 13-Oct-2004, 10:53   #7
Green1's Avatar
36mm correct ....fits like a dream - thanks to Clint
Old 13-Oct-2004, 14:18   #8
guest1 guest1 is offline
Has anyone actually read the owners manual then
No mention of how to adjust the tension in there, other than:
"Important - Have the drive chain tensioned up at a Ducati Dealer or Authorized Workshop."
Darren: was it normal socket or slim fit? When I checked mine last night the nut seems to be recessed in the swing arm.
Old 13-Oct-2004, 19:03   #9
Loz Loz is offline
Loz's Avatar
Originally posted by yellowisfriedegghow can the adjusters move the rear wheel if the axle bolt is tight ?
I guess you're right, but the chain tension does get adjusted - maybe my axle's loose?
I recall my dealer told me I don't need to slacken off the nut, so I guess we're both wrong!
Old 14-Oct-2004, 07:05   #10
guest1,a normal socket will fit fine.I think I got mine from Halfrauds.
And Loz,please tell me you are taking the mick!!??!!
How do you think those puny adjusters move the rear wheel back without undoing the spindle nut first!
As for taking the bike to a dealer to get the chain adjusted,.....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:14.
