Old 17-Oct-2004, 14:49   #1
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
front indicator pods
Mine have broken their mounting legs. Is there anywhere cheaper than ducati to buy them?
[Edited on 17-10-2004 by moozaad]
Old 17-Oct-2004, 16:04   #2
No. But they're not that much...that reminds me, I need a right hand one.
Old 17-Oct-2004, 17:11   #3
Phil Butler Phil Butler is offline
Bikes: ST2, 750ss, 350 Forza, W650, CB250RS, 5x Royal Enfields
Mood: Nesun Dorma
My RH indicator has a broken lug. I fixed it by making up a strip of thin aluminium drilling a hole at each end and used a piece of self adhesive foam under the strip to cushion it and to apply light pressure.
It has done about 10k miles since , If you know a gas man scrounge an offcut from a gas fire closure plate (Alloy not steel) and a bit of foam they use for sealing flue ducts. worked for me. Yes in a former life I was a CORGI service engineer.
Old 17-Oct-2004, 17:49   #4
Bikes: Ducati ST2
Mood: Fruity
well what happened to mine was.... I took the top fairing off and placed it on top of the clocks and upper supports. Something dislodged it and it fell on one indicator and then bounced on the other. Both broke!!! so I did a fibre glass/plastic repair kit job on them but now one side has collapsed after 12 months. So I thought it was about time I replaced it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:48.
