Old 19-Oct-2004, 20:38   #1
Andy Andy is offline
748R Hazard warning light indicators
My 2002 748R has started doing a hazard warning light trick when I turn the switch to go left or right.
Has anyone experienced this problem or cured it?
Old 19-Oct-2004, 23:30   #2
Guido's Avatar
I guess when you say 'Hazard' you mean both sides (L&R) flash at the same time????
Check all bulbs for any loose or blown connections. Only time both sides flash on mine is when the alarm or immobiliser is armed. Have you one of these on it and is there a problem there????
Have you been out in the rain at all?? Take top half off of the indicator switch on the LHS bar and clean/lube all contacts/moving parts.
Not had it myself on my '01 748R but it sounds like a simple lecky fault. Just need to find the source of it.
Good luck.
Old 07-Aug-2006, 21:48   #3
loverobot's Avatar
mine has just started doing exactly the same thing - does anyone know the cause or cure please?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:10.
